> stubborn exhaust manifold gaskets
87m491
post Feb 20 2024, 06:55 AM
Finally swapping in SS heater boxes I acquired years ago and I can't budge the existing manifold gaskets. I have read and tried a few options, trying to leverage a pick under and edge and walk it out, no luck., the gasket is very tight against the engine. Trying to lever a screwdriver head against and gasket edge and the head to deform the gasket a touch except that my head's fin started to deform before the gasket! Any other tricks before I give up and just try reusing the gaskets that won't seem to come out?
Thx
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708433712.1.jpg)
post Feb 28 2024, 11:20 AM
1/4 in Cold chisel will cut it easy
87m491   stubborn exhaust manifold gaskets   Feb 20 2024, 06:55 AM
barefoot   If they're not damaged in the sealing face, ju...   Feb 20 2024, 06:56 AM
windforfun   What is the gasket material? Can you cut them? ...   Feb 20 2024, 11:52 AM
87m491   Theoretically copper but not very malleable from m...   Feb 20 2024, 04:46 PM
TROJANMAN   When all else fails, torch it. :devil:   Feb 20 2024, 12:17 PM
Shivers   I agree, throw some flame on it.   Feb 20 2024, 12:22 PM
930cabman   It's hard for me to see, but if it's the c...   Feb 20 2024, 01:24 PM
87m491   It's hard for me to see, but if it's the ...   Feb 20 2024, 04:48 PM
GregAmy   I snag 'em with a bent pick. $10 for ...   Feb 20 2024, 05:35 PM
windforfun   I snag 'em with a bent pick. $10 for ...   Feb 20 2024, 06:05 PM
930cabman   [quote name='GregAmy' post='3129740' date='Feb 20...   Feb 20 2024, 07:08 PM
worn   [quote name='GregAmy' post='3129740' date='Feb 2...   Feb 27 2024, 08:26 PM
DC_neun_vierzehn   Sounds like someone may have applied some sealant ...   Feb 20 2024, 05:51 PM
87m491   Sounds like someone may have applied some sealant...   Feb 25 2024, 02:16 PM
Eric_Ciampa   I remember deforming one stubborn one. I might hav...   Feb 20 2024, 07:57 PM
rhodyguy   A couple of whacks on the ring with a hammer and s...   Feb 25 2024, 02:36 PM
windforfun   :agree: :agree: :agree: Cut them with a sharp ...   Feb 25 2024, 04:26 PM
technicalninja   Sounds like someone may have applied some sealan...   Feb 25 2024, 05:11 PM
930cabman   Long thin blade slotted screwdriver, a good rap...   Feb 27 2024, 02:57 PM
87m491   Deforming of single cylinder gasket on bench I co...   Feb 28 2024, 07:23 AM
930cabman   Deforming of single cylinder gasket on bench I c...   Feb 28 2024, 10:22 AM
rjames   :agree: Don't run it without replacing it...   Feb 27 2024, 08:15 PM
73-914   1/4 in Cold chisel will cut it easy   Feb 28 2024, 11:20 AM
87m491   1/4 in Cold chisel will cut it easy As with so ...   Feb 28 2024, 01:35 PM
technicalninja   I did mine in our 75 upside down. They were stuck...   Feb 28 2024, 02:36 PM
87m491   I did mine in our 75 upside down. They were stuc...   Mar 4 2024, 07:24 AM
rhodyguy   The cold steel chisel is too blunt. Consider the i...   Feb 28 2024, 03:16 PM
GregAmy   Good on you for keeping at it!   Mar 4 2024, 08:10 AM
930cabman   Glad you got it out, but I would be careful of cau...   Mar 4 2024, 09:21 AM
- Lo-Fi Version Time is now: 5th August 2026 - 04:32 AM
