Side shift transmission console shift shaft plastic washers., Before I put this together I should replace them |
Shivers |
Mar 5 2024, 06:03 PM
Senior Member Group: Members Posts: 2,407 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Mikey914 |
Mar 5 2024, 11:08 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Depending on the loading. It may be a good application for PTFE????
I do have these - https://914rubber.com/shift-guide-ring https://914rubber.com/shift-spring-guide-ring The larger one I'm not sure. |
Shivers |
Mar 6 2024, 08:08 PM
Depending on the loading. It may be a good application for PTFE???? I do have these - https://914rubber.com/shift-guide-ring https://914rubber.com/shift-spring-guide-ring The larger one I'm not sure. Thanks. These are a specific thickness. they seem to be a shim. They keep the shift shaft in the console from traveling too far so it stays ligned up with the rods. I was testing without these in and it got all fubar in the trans. Finally got the console out and had to use a screwdriver to move the rods back in place. Maybe I can find some brass at a hobby store and make some |
Lo-Fi Version | Time is now: 28th May 2024 - 08:25 PM |
