> 914-6 conversion wiring guidance
mb911
post Apr 13 2020, 01:35 PM
I have 90% of the harness connections made.. My biggest issue is that I am not 100% sure where the voltage regulator wires in.. Should the blue DF wire go to the regulator from the engine go to the regulator then back to the main harness? What about the black wire from the alternator? I believe that hooks onto the brush pack on the back of the alternator but does that directly hook into main harness plug?
I have everything else figured out.. Attached Image
roblav1
post Apr 13 2020, 06:00 PM
Holy cow! Thank you. I'm at the same place as Ben, but my engine is 930/02 with a new internal alternator.
ClayPerrine
post Apr 14 2020, 02:46 AM
QUOTE(roblav1 @ Apr 13 2020, 07:00 PM) *
Yours is very simple. Look at the 4 cylinder relay board. there is a 3 pin connector where the /4 alternator harness plugs in. Coming from the alternator, there is a single blue wire. Hook the single blue wire to the front most pin on the 3 pin alternator connector.
Clay
930cabman
post Mar 15 2024, 05:12 PM
QUOTE(ClayPerrine @ Apr 14 2020, 02:46 AM) *
Clay
Clay,
Please confirm which is the "front most pin" on the /4 relay board. I am just about ready to turn the ignition switch for the first time with this multi year /6 conversion build. Alternator with built in regulator has been tested. Besides the blue wire, I also have an extra red wire.
Thank you
mb911   914-6 conversion wiring guidance   Apr 13 2020, 01:35 PM
mb911   Looks like the DF wire is actually the black wire....   Apr 13 2020, 01:43 PM
ClayPerrine   What year is your engine/alternator? Is it inter...   Apr 13 2020, 01:53 PM
mb911   Clay its a 73 engine with a fresh SEV Marchal alte...   Apr 13 2020, 01:57 PM
raynekat   Clay its a 73 engine with a fresh SEV Marchal alt...   Apr 13 2020, 08:59 PM
mb911   Clay its a 73 engine with a fresh SEV Marchal al...   Apr 14 2020, 05:36 AM
ClayPerrine   It should wire up exactly like the /4 alternator, ...   Apr 13 2020, 02:10 PM
dr914@autoatlanta.com   I cannot remember, but have the correct wiring adv...   Apr 13 2020, 02:16 PM
914forme   The author is agreeing to intellectual property sw...   Apr 13 2020, 03:11 PM
914forme   It is a nice little book, and reference to have ar...   Apr 13 2020, 03:15 PM
914forme   And the other two pages of wiring reference.   Apr 13 2020, 03:20 PM
dr914@autoatlanta.com   Thank you.   Apr 13 2020, 03:22 PM
914forme   More than welcome   Apr 13 2020, 03:24 PM
mb911   Thanks.. Now keep in mind not using the relay boar...   Apr 13 2020, 03:43 PM
mlindner   Hey Ben, get a hold of Perry Kiehl. I think he wou...   Apr 13 2020, 04:15 PM
mb911   I will ping @ironhillrestorations   Apr 13 2020, 04:17 PM
IronHillRestorations   The blue charge light wire goes to D+   Apr 13 2020, 05:28 PM
mb911   Thats how I have it wired.. Thanks   Apr 13 2020, 05:41 PM
roblav1   Holy cow! Thank you. I'm at the same pla...   Apr 13 2020, 06:00 PM
ClayPerrine   Holy cow! Thank you. I'm at the same pl...   Apr 14 2020, 02:46 AM
roblav1   Thank you very much Clay. Holy cow! Thank ...   Apr 14 2020, 06:07 PM
930cabman   Holy cow! Thank you. I'm at the same p...   Mar 15 2024, 05:12 PM
ClayPerrine   [quote name='ClayPerrine' post='2804127' date='Ap...   Mar 16 2024, 04:14 AM
930cabman   [quote name='ClayPerrine' post='2804127' date='A...   Mar 16 2024, 04:41 PM
IronHillRestorations   You should've told me you needed the terminals...   Apr 13 2020, 06:01 PM
mb911   One question I do have is the black wire coming fr...   Apr 14 2020, 05:38 AM
IronHillRestorations   Just got up so still foggy, but I'm pretty sur...   Apr 14 2020, 06:14 AM
mb911   Thanks Perry.. Getting the wiring wrapped up this ...   Apr 14 2020, 10:38 AM
Chuck53   I have 90% of the harness connections made.. My b...   Apr 26 2020, 12:07 PM
gereed75   Welcome Chuck. Where do you live in PA?   Apr 26 2020, 01:34 PM
Chuck53   Welcome Chuck. Where do you live in PA? Slatin...   Apr 26 2020, 02:04 PM
mepstein   Welcome Chuck. Where do you live in PA? Slati...   Apr 26 2020, 04:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:23 PM
