mb911
Apr 13 2020, 01:35 PM
I have 90% of the harness connections made.. My biggest issue is that I am not 100% sure where the voltage regulator wires in.. Should the blue DF wire go to the regulator from the engine go to the regulator then back to the main harness? What about the black wire from the alternator? I believe that hooks onto the brush pack on the back of the alternator but does that directly hook into main harness plug?
I have everything else figured out..
mb911
Apr 13 2020, 01:43 PM
Looks like the DF wire is actually the black wire.. So does the blue wire make a side track to the regulator as well?
http://forums.pelicanparts.com/porsche-911...ing-ground.html
ClayPerrine
Apr 13 2020, 01:53 PM
What year is your engine/alternator? Is it internally regulated or externally regulated?
Clay
mb911
Apr 13 2020, 01:57 PM
Clay its a 73 engine with a fresh SEV Marchal alternator
ClayPerrine
Apr 13 2020, 02:10 PM
It should wire up exactly like the /4 alternator, with the exception that the wiring is contained in the engine harness. You can separate it from the engine harness so you can remove the engine harness without removing the fan shroud.
You can even extend the wires on a /4 alternator harness to make it work.
And use a Marchal regulator, not the Bosch one. It works better with the Marchal alternator.
dr914@autoatlanta.com
Apr 13 2020, 02:16 PM
I cannot remember, but have the correct wiring advice in my pamphlet "how to convert if someone could swipe it and post here for ben
914forme
Apr 13 2020, 03:11 PM
The author is agreeing to intellectual property swipage.
Where did I put that phampleqte
See below, credit taken from credit given. George Asked gladly deliver
Click to view attachmentClick to view attachment
914forme
Apr 13 2020, 03:15 PM
It is a nice little book, and reference to have around, if you can afford it, it is one of the nice pieces that truly help the 914 world.
914forme
Apr 13 2020, 03:20 PM
Apr 13 2020, 03:22 PM
Thank you.
914forme
Apr 13 2020, 03:24 PM
More than welcome
mb911
Apr 13 2020, 03:43 PM
Thanks.. Now keep in mind not using the relay board.. I checked the wiring diagrams and believe this is correct.. I temped in the regulator
mlindner
Apr 13 2020, 04:15 PM
Hey Ben, get a hold of Perry Kiehl. I think he would have the answer for you. Best, Mark
mb911
Apr 13 2020, 04:17 PM
IronHillRestorations
Apr 13 2020, 05:28 PM
The blue charge light wire goes to D+
mb911
Apr 13 2020, 05:41 PM
Thats how I have it wired.. Thanks
roblav1
Apr 13 2020, 06:00 PM
Holy cow! Thank you. I'm at the same place as Ben, but my engine is 930/02 with a new internal alternator.
Apr 13 2020, 06:01 PM
You should've told me you needed the terminals. I have the locking ones for the VR plug
raynekat
Apr 13 2020, 08:59 PM
QUOTE(mb911 @ Apr 13 2020, 12:57 PM)
Hope you are not using a Bosch voltage regulator with that SEV Marchal alternator. It's a mismatch big time and you'll not have enough voltage at the battery.
ClayPerrine
Apr 14 2020, 02:46 AM
QUOTE(roblav1 @ Apr 13 2020, 07:00 PM)
Yours is very simple. Look at the 4 cylinder relay board. there is a 3 pin connector where the /4 alternator harness plugs in. Coming from the alternator, there is a single blue wire. Hook the single blue wire to the front most pin on the 3 pin alternator connector.
Clay
mb911
Apr 14 2020, 05:36 AM
QUOTE(raynekat @ Apr 13 2020, 06:59 PM)
Nope using the SEV regulator..
mb911
Apr 14 2020, 05:38 AM
One question I do have is the black wire coming from the chassis harness switched 12v from the key switch?
Apr 14 2020, 06:14 AM
Just got up so still foggy, but I'm pretty sure you are correct
mb911
Apr 14 2020, 10:38 AM
Thanks Perry.. Getting the wiring wrapped up this week is my goal along with all fuel and oil connections..
roblav1
Apr 14 2020, 06:07 PM
Thank you very much Clay.
QUOTE(ClayPerrine @ Apr 14 2020, 04:46 AM)
Clay
Chuck53
Apr 26 2020, 12:07 PM
QUOTE(mb911 @ Apr 13 2020, 03:35 PM)
Click to view attachmentI have a 1970 914-6 and have spent plenty of time going through the wiring, so I can see why you are having problems. First of all, a regulator board is different on a 914-4 and 914-6. Secondly, the wires going to my alternator are Big red to B+, Small Red to D+, Black to DF and Brown to Ground. I do not have a blue wire. The Small Red, Black and Brown goes to the regulator board as a 3 prong plug that daisy chains to the voltage regulator. Hope this helps.
gereed75
Apr 26 2020, 01:34 PM
Welcome Chuck. Where do you live in PA?
Chuck53
Apr 26 2020, 02:04 PM
QUOTE(gereed75 @ Apr 26 2020, 03:34 PM)
Slatington, Pa, close to Coplay, Pa
Apr 26 2020, 04:24 PM
QUOTE(Chuck53 @ Apr 26 2020, 04:04 PM)
930cabman
Mar 15 2024, 05:12 PM
QUOTE(ClayPerrine @ Apr 14 2020, 02:46 AM)
Clay
Clay,
Please confirm which is the "front most pin" on the /4 relay board. I am just about ready to turn the ignition switch for the first time with this multi year /6 conversion build. Alternator with built in regulator has been tested. Besides the blue wire, I also have an extra red wire.
Thank you
ClayPerrine
Mar 16 2024, 04:14 AM
QUOTE(930cabman @ Mar 15 2024, 06:12 PM)
Clay
Clay,
Thank you
Take a look at this diagram:
The wire from the alternator needs to be hooked to the "D+" connection on the relay board. It is the one with the Blue wire in the diagram. Hook the blue wire from the alternator to that connection.
930cabman
Mar 16 2024, 04:41 PM
QUOTE(ClayPerrine @ Mar 16 2024, 04:14 AM)
Clay
Clay,
Thank you
Great information, thanks again.
