914-6 conversion wiring guidance |
mb911 |
Apr 13 2020, 01:35 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have 90% of the harness connections made.. My biggest issue is that I am not 100% sure where the voltage regulator wires in.. Should the blue DF wire go to the regulator from the engine go to the regulator then back to the main harness? What about the black wire from the alternator? I believe that hooks onto the brush pack on the back of the alternator but does that directly hook into main harness plug?
I have everything else figured out.. |
mb911 |
Apr 13 2020, 01:43 PM
Looks like the DF wire is actually the black wire.. So does the blue wire make a side track to the regulator as well?
http://forums.pelicanparts.com/porsche-911...ing-ground.html |
ClayPerrine |
Apr 13 2020, 01:53 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
What year is your engine/alternator? Is it internally regulated or externally regulated?
Clay |
mb911 |
Apr 13 2020, 01:57 PM
Clay its a 73 engine with a fresh SEV Marchal alternator
ClayPerrine |
Apr 13 2020, 02:10 PM
It should wire up exactly like the /4 alternator, with the exception that the wiring is contained in the engine harness. You can separate it from the engine harness so you can remove the engine harness without removing the fan shroud.
You can even extend the wires on a /4 alternator harness to make it work. And use a Marchal regulator, not the Bosch one. It works better with the Marchal alternator. |
dr914@autoatlanta.com |
Apr 13 2020, 02:16 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I cannot remember, but have the correct wiring advice in my pamphlet "how to convert if someone could swipe it and post here for ben
914forme |
Apr 13 2020, 03:11 PM
The author is agreeing to intellectual property swipage. (IMG:style_emoticons/default/screwy.gif)
Where did I put that phampleqte See below, credit taken from credit given. George Asked gladly deliver |
914forme |
Apr 13 2020, 03:15 PM
It is a nice little book, and reference to have around, if you can afford it, it is one of the nice pieces that truly help the 914 world.
914forme |
Apr 13 2020, 03:20 PM
Apr 13 2020, 03:22 PM
Thank you.
914forme |
Apr 13 2020, 03:24 PM
More than welcome
mb911 |
Apr 13 2020, 03:43 PM
mlindner |
Apr 13 2020, 04:15 PM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Hey Ben, get a hold of Perry Kiehl. I think he would have the answer for you. Best, Mark
mb911 |
Apr 13 2020, 04:17 PM
I will ping @ironhillrestorations
IronHillRestorations |
Apr 13 2020, 05:28 PM
The blue charge light wire goes to D+
mb911 |
Apr 13 2020, 05:41 PM
Thats how I have it wired.. Thanks
roblav1 |
Apr 13 2020, 06:00 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Holy cow! Thank you. I'm at the same place as Ben, but my engine is 930/02 with a new internal alternator.
Apr 13 2020, 06:01 PM
You should've told me you needed the terminals. I have the locking ones for the VR plug
raynekat |
Apr 13 2020, 08:59 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
ClayPerrine |
Apr 14 2020, 02:46 AM
Holy cow! Thank you. I'm at the same place as Ben, but my engine is 930/02 with a new internal alternator. Yours is very simple. Look at the 4 cylinder relay board. there is a 3 pin connector where the /4 alternator harness plugs in. Coming from the alternator, there is a single blue wire. Hook the single blue wire to the front most pin on the 3 pin alternator connector. Clay |
Lo-Fi Version | Time is now: 16th May 2024 - 05:03 PM |
