3D Printable Goodies. |
gnomefabtech |
Apr 7 2024, 07:48 PM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
I'm editing this thread to just be a general 3D printable items thread. I also added an adaptor ring to allow a Speedhut Tach to fit in our dash holes.
I added onto the dummy ashtray model available online and made a pod for my boost gauge. Looks good and is definitely easy to see. I'll attach the .stl file in the comments if I can. Enjoy. |
gnomefabtech |
Apr 8 2024, 05:39 PM
https://www.myminifactory.com/object/3d-pri...uge-pods-372458
Here is the link to myminifactory. I don't know when it will be approved but I can't imagine why it wouldn't be. Both sizes. 52mm and 65mm. Two 52mm won't fit although there might be a way if they stick out a lot. |
fixer34 |
Apr 8 2024, 08:42 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
https://www.myminifactory.com/object/3d-pri...uge-pods-372458 Here is the link to myminifactory. I don't know when it will be approved but I can't imagine why it wouldn't be. Both sizes. 52mm and 65mm. Two 52mm won't fit although there might be a way if they stick out a lot. There is a rubber VDO dual gauge mount in the classifieds, maybe along that design? I seem to remember the back of the gauges would just clear the dash underneath. |
rgalla9146 |
Apr 11 2024, 04:25 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
https://www.myminifactory.com/object/3d-pri...uge-pods-372458 Here is the link to myminifactory. I don't know when it will be approved but I can't imagine why it wouldn't be. Both sizes. 52mm and 65mm. Two 52mm won't fit although there might be a way if they stick out a lot. There is a rubber VDO dual gauge mount in the classifieds, maybe along that design? I seem to remember the back of the gauges would just clear the dash underneath. Requires drilling two holes for sheet metal screws. Vintage VDO part... if you can find it. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:10 PM |
