| DC_neun_vierzehn |
Apr 13 2024, 08:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
My wiper assembly is not parking properly (as discussed in this post) so I need to perform the dreaded task of pulling the fresh air box to get to the wiper assembly. I've watched Ian's video which is super helpful.
I'd like to rebuild the air box while I have it out. I bought the 914 Rubber kit to replace all of the seals and grill. I'd like to replace the fan motor too while I'm in there. My question: is this the right part (or best part) for a 914 fresh air box? https://sierramadrecollection.com/products/...ly-69-89-p18608 |
| 914sgofast2 |
Apr 18 2024, 12:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 779 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
When I did my airbox, I found that the new gasket that fits between the upper and lower halves of the plastic airbox was too thick, once you put the new upper gasket onto the top of the airbag and tried to re-install the assembly under the body cowl sheetmetal. So, I took out the plastic airbox' middle gasket used a bead of black silicon to seal the motor lower half against the airbox' upper half. With that modification, the refreshed air box fit into place just fine without the need for Ian Karr's tool setup or the need to remove the hood. The metal body cowl area is pretty flexible if you remove the bolts on each of the metal arms which support the upper cowl sheetmetal.
DC_neun_vierzehn Fresh Air Box Rebuild - Replacing Blower Motor Apr 13 2024, 08:21 AM
914Sixer Should work fine. $10 cheaper at Rockauto. Apr 13 2024, 08:30 AM
PanelBilly I replaced mine and was so happy to have a defrost... Apr 13 2024, 10:22 AM
jim_hoyland Do the new replacement fan motors put out more air... Apr 13 2024, 10:42 AM
PanelBilly Seems like it bur it might just be that they work ... Apr 13 2024, 12:32 PM
76-914 FYI, You won't be able to use Ian's clamp ... Apr 14 2024, 07:23 AM
DC_neun_vierzehn Thanks everyone. Appreciate the pointers. I need a... Apr 14 2024, 03:32 PM
jim_hoyland
Thanks everyone. Appreciate the pointers. I need ... Apr 15 2024, 06:44 AM
DC_neun_vierzehn
Thanks everyone. Appreciate the pointers. I need... Apr 16 2024, 09:35 AM
DRPHIL914
Do the new replacement fan motors put out more ai... Apr 18 2024, 11:06 AM
jim_hoyland
[quote name='jim_hoyland' post='3139359' date='Ap... Apr 18 2024, 11:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2025 - 12:16 PM |
