| Zaffer |
Apr 20 2024, 08:04 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
I know this subject has been beaten to death, but just trying to look for the most current information on parts as I know quality changes over time.
I am no longer doing a Subaru six conversion to my 914 as I will keep the T4. I have 2, one 2.0L and one 1.8L. My car is a factory ‘75 2.0L. I will run factory FI and am not interested in Megasquirt, carbs, or any other aftermarket FI, at least for now. The 2.0L I’m using I bought from George Hussey in 2009 “in running condition”, but it’s been sitting on my engine stand since. I am going to rebuild my 2.0L and bump it up to a 2056, but have some (a lot of) questions: Can I use the factory FI for a 2270? I don’t think so, IIRC, but want to make sure. I have the 1.8L that I could make a 1911, but is it any better than a 2056? Why or why not? What P&C’s should I use? I know the main ones are AA and KB. I’m looking at the Biral AA’s at the moment. Can I use a more aggressive cam with factory FI? What valve springs should I use and is there a better setup? My initial plan is as follows: - Install new P&C’s - Balance the crankshaft, rods, and pistons - Rebuild the heads: replace/upgrade the valve springs, replace the valve guides, inspect and replace/upgrade(?) valves - Either use factory cam or upgrade cam, if possible with factory FI. - Install a larger oil pump, if still available. While I want to make some improvements with the engine, I am not going to spend 10K+ doing so. This car will be a nice weather driver and I do not plan on doing any track events or autoX’s with it. I want to make the engine nice and “reliable”, but I don’t need new heads, Nickies, etc. I am rebuilding the engine myself but using a really good local machine shop as well. I do not need to get every Nth of power from the engine, but would like to reasonably improve on it without going crazy. Any advice on what to, and not to, do is welcome and I realize I’m going to get multiple different answers. As for the car itself, it’ll remain mostly stock with Factory 4-lug Fuchs, factory brakes, etc. Thanks! |
| Superhawk996 |
Apr 21 2024, 07:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I’ll add - a 1911 is plenty of fun especially with a cam and carbs. Cheap to build since you avoid the potential cost issues of the 2.0l heads. Even if you go 1911 and Stock FI, it is still a fun engine, just leaves a little HP on the table by not being able to use a more aggressive cam profile.
Stay 2056 or 1911 and a rebuild is very affordable. I drove a 1911, for years and years when I rebuilt my 1st 1.7L. Very reliable. Start going down the path of big bore and strokers and costs escalate very quickly. Likewise reliability of those types of engines diminishes quickly unless the build is done to a high standard including Nickies which tank the budget aspect. |
| Zaffer |
Apr 23 2024, 04:25 AM
I’ll add - a 1911 is plenty of fun especially with a cam and carbs. Cheap to build since you avoid the potential cost issues of the 2.0l heads. Even if you go 1911 and Stock FI, it is still a fun engine, just leaves a little HP on the table by not being able to use a more aggressive cam profile. Stay 2056 or 1911 and a rebuild is very affordable. I drove a 1911, for years and years when I rebuilt my 1st 1.7L. Very reliable. Start going down the path of big bore and strokers and costs escalate very quickly. Likewise reliability of those types of engines diminishes quickly unless the build is done to a high standard including Nickies which tank the budget aspect. I’m definitely not going down the path of big bore/striker engines because, yes, it does get expensive fast! What all is in the 1911 build? If I keep the T4, I’m planning on keeping the factory FI, which I know limits the size and cam, but that’s what I would want to do. Can the FI from the 2.0L be used on the 1911? I do have a spare 1.8L. I guess first thing to do would be to have the heads checked and then decide: if they’re good, stick with the T4; if bad, then consider the conversion. My problem is I want more power, but I like the idea of keeping the T4. However, I’m not spending 10K on an uber nice T4 for 120hp. What would a “basic” rebuild be, with me doing the labor side, besides machine work? Prices are all over he place so looking for experience. |
Zaffer 2.0L rebuild Apr 20 2024, 08:04 AM
technicalninja First thing is to disassemble what you have and ma... Apr 20 2024, 08:57 AM
Geezer914 I rebuilt my 2.0 to 2056 using AA biral cylinders ... Apr 20 2024, 06:54 PM
Zaffer Well, after doing more research, I’m reminded of... Apr 21 2024, 10:24 AM
Superhawk996 No way a subie conversion is simpler than a basic ... Apr 21 2024, 10:30 AM
No way a subie conversion is simpler than a basic... Apr 21 2024, 11:12 AM
Zaffer
No way a subie conversion is simpler than a basi... Apr 23 2024, 04:19 AM
Highland
I’ll add - a 1911 is plenty of fun especially ... Apr 24 2024, 06:17 PM
Superhawk996 Don’t make like more complicated by creating T4 ... Apr 23 2024, 07:08 AM
Superhawk996 With respect to price for basic T4 rebuild:
New ... Apr 23 2024, 07:17 AM
Zaffer
New... Apr 23 2024, 08:22 AM
Superhawk996 Resized rods are simply returning OEM rods to spec... Apr 23 2024, 08:34 AM
Zaffer
Resized rods are simply returning OEM rods to spe... Apr 23 2024, 08:49 AM
technicalninja "I own a Euro repair shop."
"New li... Apr 23 2024, 09:29 AM
Zaffer
"New l... Apr 23 2024, 10:43 AM
technicalninja I'm a bit of a take no prisoners type of guy. ... Apr 23 2024, 11:55 AM
ctc911ctc Best Laugh of my Week! Well Done!
I... Apr 26 2024, 06:47 AM
Zaffer Not a problem and I appreciate the explanation. I ... Apr 24 2024, 12:29 PM
Superhawk996 :headbanger: motorsports crew work is largely a y... Apr 24 2024, 01:47 PM
Zaffer I don’t miss the work or the all-nighters swappi... Apr 24 2024, 05:24 PM
technicalninja
...but the machine shop I use seems really good a... Apr 24 2024, 08:38 PM
technicalninja
Are the basic AA heads worth a damn? The price i... Apr 24 2024, 09:20 PM
Zaffer I mainly asking in case one or both heads are crac... Apr 25 2024, 01:48 PM
Jack Standz Sorry to hear about your ankle. Hope you heal up ... Apr 25 2024, 05:25 PM
technicalninja I believe that the big guys (Raby/LN) are still mo... Apr 25 2024, 05:52 PM
r_towle I’m going to offer an idea.
Take the 2.0 liter o... Apr 25 2024, 08:54 PM
VaccaRabite
Take the 2.0 liter ... Apr 26 2024, 06:21 AM
Superhawk996
Finally, you can do a subi swap for about the sa... Apr 26 2024, 07:48 AM
Zaffer
Take the 2.0 liter... Apr 27 2024, 04:59 AM
Superhawk996
As for the other engine, it’s just a 1.8L lon... Apr 27 2024, 11:28 AM
Geezer914 The 914 is known for its handling. If you want it... Apr 26 2024, 10:28 AM
technicalninja Why are you limiting yourself with the factory int... Apr 27 2024, 11:25 AM
technicalninja :agree: :agree: :agree:
The stock FI is the si... Apr 27 2024, 01:17 PM
Zaffer I don’t know if the FI system I have is perfectl... Apr 27 2024, 05:49 PM
Superhawk996
My daughters don’t show a lot of interest when ... Apr 27 2024, 09:32 PM
Zaffer
[quote name='Zaffer' post='3141887' date='Apr 27 ... Apr 28 2024, 05:05 AM
Zaffer Well, I’m one step closer to starting back on my... May 1 2024, 01:53 PM
Geezer914 I used my Ljet injection when I built my 2056. I ... May 1 2024, 04:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:39 AM |
