| Zaffer |
Apr 20 2024, 08:04 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
I know this subject has been beaten to death, but just trying to look for the most current information on parts as I know quality changes over time.
I am no longer doing a Subaru six conversion to my 914 as I will keep the T4. I have 2, one 2.0L and one 1.8L. My car is a factory ‘75 2.0L. I will run factory FI and am not interested in Megasquirt, carbs, or any other aftermarket FI, at least for now. The 2.0L I’m using I bought from George Hussey in 2009 “in running condition”, but it’s been sitting on my engine stand since. I am going to rebuild my 2.0L and bump it up to a 2056, but have some (a lot of) questions: Can I use the factory FI for a 2270? I don’t think so, IIRC, but want to make sure. I have the 1.8L that I could make a 1911, but is it any better than a 2056? Why or why not? What P&C’s should I use? I know the main ones are AA and KB. I’m looking at the Biral AA’s at the moment. Can I use a more aggressive cam with factory FI? What valve springs should I use and is there a better setup? My initial plan is as follows: - Install new P&C’s - Balance the crankshaft, rods, and pistons - Rebuild the heads: replace/upgrade the valve springs, replace the valve guides, inspect and replace/upgrade(?) valves - Either use factory cam or upgrade cam, if possible with factory FI. - Install a larger oil pump, if still available. While I want to make some improvements with the engine, I am not going to spend 10K+ doing so. This car will be a nice weather driver and I do not plan on doing any track events or autoX’s with it. I want to make the engine nice and “reliable”, but I don’t need new heads, Nickies, etc. I am rebuilding the engine myself but using a really good local machine shop as well. I do not need to get every Nth of power from the engine, but would like to reasonably improve on it without going crazy. Any advice on what to, and not to, do is welcome and I realize I’m going to get multiple different answers. As for the car itself, it’ll remain mostly stock with Factory 4-lug Fuchs, factory brakes, etc. Thanks! |
| Superhawk996 |
Apr 23 2024, 07:08 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Don’t make like more complicated by creating T4 Frankenbuilds by mixing and matching FI.
Rebuild a 1.8 to 1911 (66 x 96) use 1.8L FI which will fit 1.8L heads. Rebuild 2.0l to 2056 (71 x 96) use 2.0L FI that fits 3 stud 2.0L heads. The factory FI is limiting because it cannot accommodate large changes in volumetric efficiency that come with increases in bore, stroke, and cam. It can handle the minor displacement change. It cannot handle much of a cam change. The 2.0L is basically a factory stroker that added 5mm stroke. The increased HP of the 2.0l doesn’t come from some sort of magic 2.0l FI, it comes from the added stroke and the 2.0l heads that had better flow and a better spark plug orientation for a better burn. I’m going to give you my opinion on HP. It doesn’t matter. (Worth what you paid). Especially in a day and age of EV’s. Even with a Subie it will still be “slow”. Your average daily driver now can do 0-60 very close to what a 930 used to be. These cars were never about HP. They were about light weight and superb handling. The ability to carry momentum in turns. The stock 914 is air cooled and has a very low polar moment of inertia as a result of centralized engine mass. By the time you’ve added the extra weight and plumbing of a subie and compromised the centralized mass with a radiator, much of what defined the original 914 is lost. After all that work to do a conversion, you still don’t have a “fast” car by modern standards. The 2021 Toyota Camry was 0-60 in about 6 seconds. Let that sink in. These are facts and physics. A good driver in a 100 Hp car can out drive an average driver in the same car with 130 HP on track or in the twisties. A professional driver in 100 hp will make a mockery of an average driver with 200 or more HP. You get the point. If you truly feel big horsepower is what you want, the T4 isn’t for you. If you just want to do smoky burnouts - put a T4 rebuild out of your mind. If you just want a more modern power plant, move forward on a conversion with zero regret. |
Zaffer 2.0L rebuild Apr 20 2024, 08:04 AM
technicalninja First thing is to disassemble what you have and ma... Apr 20 2024, 08:57 AM
Geezer914 I rebuilt my 2.0 to 2056 using AA biral cylinders ... Apr 20 2024, 06:54 PM
Zaffer Well, after doing more research, I’m reminded of... Apr 21 2024, 10:24 AM
Superhawk996 No way a subie conversion is simpler than a basic ... Apr 21 2024, 10:30 AM
No way a subie conversion is simpler than a basic... Apr 21 2024, 11:12 AM
Zaffer
No way a subie conversion is simpler than a basi... Apr 23 2024, 04:19 AM
Superhawk996 I’ll add - a 1911 is plenty of fun especially w... Apr 21 2024, 07:49 PM
Zaffer
I’ll add - a 1911 is plenty of fun especially ... Apr 23 2024, 04:25 AM
Highland
I’ll add - a 1911 is plenty of fun especially ... Apr 24 2024, 06:17 PM
Superhawk996 With respect to price for basic T4 rebuild:
New ... Apr 23 2024, 07:17 AM
Zaffer
New... Apr 23 2024, 08:22 AM
Superhawk996 Resized rods are simply returning OEM rods to spec... Apr 23 2024, 08:34 AM
Zaffer
Resized rods are simply returning OEM rods to spe... Apr 23 2024, 08:49 AM
technicalninja "I own a Euro repair shop."
"New li... Apr 23 2024, 09:29 AM
Zaffer
"New l... Apr 23 2024, 10:43 AM
technicalninja I'm a bit of a take no prisoners type of guy. ... Apr 23 2024, 11:55 AM
ctc911ctc Best Laugh of my Week! Well Done!
I... Apr 26 2024, 06:47 AM
Zaffer Not a problem and I appreciate the explanation. I ... Apr 24 2024, 12:29 PM
Superhawk996 :headbanger: motorsports crew work is largely a y... Apr 24 2024, 01:47 PM
Zaffer I don’t miss the work or the all-nighters swappi... Apr 24 2024, 05:24 PM
technicalninja
...but the machine shop I use seems really good a... Apr 24 2024, 08:38 PM
technicalninja
Are the basic AA heads worth a damn? The price i... Apr 24 2024, 09:20 PM
Zaffer I mainly asking in case one or both heads are crac... Apr 25 2024, 01:48 PM
Jack Standz Sorry to hear about your ankle. Hope you heal up ... Apr 25 2024, 05:25 PM
technicalninja I believe that the big guys (Raby/LN) are still mo... Apr 25 2024, 05:52 PM
r_towle I’m going to offer an idea.
Take the 2.0 liter o... Apr 25 2024, 08:54 PM
VaccaRabite
Take the 2.0 liter ... Apr 26 2024, 06:21 AM
Superhawk996
Finally, you can do a subi swap for about the sa... Apr 26 2024, 07:48 AM
Zaffer
Take the 2.0 liter... Apr 27 2024, 04:59 AM
Superhawk996
As for the other engine, it’s just a 1.8L lon... Apr 27 2024, 11:28 AM
Geezer914 The 914 is known for its handling. If you want it... Apr 26 2024, 10:28 AM
technicalninja Why are you limiting yourself with the factory int... Apr 27 2024, 11:25 AM
technicalninja :agree: :agree: :agree:
The stock FI is the si... Apr 27 2024, 01:17 PM
Zaffer I don’t know if the FI system I have is perfectl... Apr 27 2024, 05:49 PM
Superhawk996
My daughters don’t show a lot of interest when ... Apr 27 2024, 09:32 PM
Zaffer
[quote name='Zaffer' post='3141887' date='Apr 27 ... Apr 28 2024, 05:05 AM
Zaffer Well, I’m one step closer to starting back on my... May 1 2024, 01:53 PM
Geezer914 I used my Ljet injection when I built my 2056. I ... May 1 2024, 04:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:15 PM |
