| Zaffer |
Apr 20 2024, 08:04 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
I know this subject has been beaten to death, but just trying to look for the most current information on parts as I know quality changes over time.
I am no longer doing a Subaru six conversion to my 914 as I will keep the T4. I have 2, one 2.0L and one 1.8L. My car is a factory ‘75 2.0L. I will run factory FI and am not interested in Megasquirt, carbs, or any other aftermarket FI, at least for now. The 2.0L I’m using I bought from George Hussey in 2009 “in running condition”, but it’s been sitting on my engine stand since. I am going to rebuild my 2.0L and bump it up to a 2056, but have some (a lot of) questions: Can I use the factory FI for a 2270? I don’t think so, IIRC, but want to make sure. I have the 1.8L that I could make a 1911, but is it any better than a 2056? Why or why not? What P&C’s should I use? I know the main ones are AA and KB. I’m looking at the Biral AA’s at the moment. Can I use a more aggressive cam with factory FI? What valve springs should I use and is there a better setup? My initial plan is as follows: - Install new P&C’s - Balance the crankshaft, rods, and pistons - Rebuild the heads: replace/upgrade the valve springs, replace the valve guides, inspect and replace/upgrade(?) valves - Either use factory cam or upgrade cam, if possible with factory FI. - Install a larger oil pump, if still available. While I want to make some improvements with the engine, I am not going to spend 10K+ doing so. This car will be a nice weather driver and I do not plan on doing any track events or autoX’s with it. I want to make the engine nice and “reliable”, but I don’t need new heads, Nickies, etc. I am rebuilding the engine myself but using a really good local machine shop as well. I do not need to get every Nth of power from the engine, but would like to reasonably improve on it without going crazy. Any advice on what to, and not to, do is welcome and I realize I’m going to get multiple different answers. As for the car itself, it’ll remain mostly stock with Factory 4-lug Fuchs, factory brakes, etc. Thanks! |
| technicalninja |
Apr 23 2024, 11:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
I'm a bit of a take no prisoners type of guy. Sorry if I offended.
I've been wrenching since the birth of the check engine light. OBD2 was 15 years in the future. If you don't have an internal motor gearhead friend finding one (who knows his shit!) is the VERY QUICKEST way to gain knowledge yourself. I got INSANELY lucky as a starting tech to hit 3 special things... I found a really good machine shop that specialized in import ONLY way back in the early 80s. Their "specialty" was air-cooled VW. They still exist today. https://www.automotivemachine.com/ I met Eric when he was 4 years old. He followed in his father Tom's footprints. I worked for Corky Bell at Cartech Turbo Systems as one of my first jobs. I was a "lot lizard" and did everything everyone else did not want too. My first "wrenching" job was in a shop were everyone else was Jedi master level. I didn't know how lucky it was to see "excellence" first. Later I worked for Bill Sours at Passport Engines as the warranty tech. I had 18 months of "finding the root cause" of engine failures for warranty claim purposes. I've seen SOO many ways to get it wrong. That completely destroyed my faith in most shops. I once found a set of missing Corvette keys embedded in a Volvo piston... Bill was an engine master and lover of Italian cars. He showed me the way you have to approach work on Italians and exotics... It was my friends and work mates that had the greatest effect on how quickly I picked this crap up. Now, years ago rebuilding both engines and transmissions were a common job, and they are far more reliable today. Back then 100K engine life was great. Today the figure is 300K. I can see how a guy might not have that much exposure, especially if he's been working at a dealership who commonly are simple unit replacers now. You will find most "gearheads" are getting old. I'm 59... Sorry if I came off too strong. Getting good mentors early was the single greatest catalyst for me! Reading back I can see how it looks like I was critical of you as you are a professional. I was not. I was stating how an enthusiast could be a good mentor, you don't have to earn your living at this to be truly excellent. I was trying to suggest sources for your mental toolbox. (IMG:style_emoticons/default/ninja.gif) |
Zaffer 2.0L rebuild Apr 20 2024, 08:04 AM
technicalninja First thing is to disassemble what you have and ma... Apr 20 2024, 08:57 AM
Geezer914 I rebuilt my 2.0 to 2056 using AA biral cylinders ... Apr 20 2024, 06:54 PM
Zaffer Well, after doing more research, I’m reminded of... Apr 21 2024, 10:24 AM
Superhawk996 No way a subie conversion is simpler than a basic ... Apr 21 2024, 10:30 AM
No way a subie conversion is simpler than a basic... Apr 21 2024, 11:12 AM
Zaffer
No way a subie conversion is simpler than a basi... Apr 23 2024, 04:19 AM
Superhawk996 I’ll add - a 1911 is plenty of fun especially w... Apr 21 2024, 07:49 PM
Zaffer
I’ll add - a 1911 is plenty of fun especially ... Apr 23 2024, 04:25 AM
Highland
I’ll add - a 1911 is plenty of fun especially ... Apr 24 2024, 06:17 PM
Superhawk996 Don’t make like more complicated by creating T4 ... Apr 23 2024, 07:08 AM
Superhawk996 With respect to price for basic T4 rebuild:
New ... Apr 23 2024, 07:17 AM
Zaffer
New... Apr 23 2024, 08:22 AM
Superhawk996 Resized rods are simply returning OEM rods to spec... Apr 23 2024, 08:34 AM
Zaffer
Resized rods are simply returning OEM rods to spe... Apr 23 2024, 08:49 AM
technicalninja "I own a Euro repair shop."
"New li... Apr 23 2024, 09:29 AM
Zaffer
"New l... Apr 23 2024, 10:43 AM
ctc911ctc Best Laugh of my Week! Well Done!
I... Apr 26 2024, 06:47 AM
Zaffer Not a problem and I appreciate the explanation. I ... Apr 24 2024, 12:29 PM
Superhawk996 :headbanger: motorsports crew work is largely a y... Apr 24 2024, 01:47 PM
Zaffer I don’t miss the work or the all-nighters swappi... Apr 24 2024, 05:24 PM
technicalninja
...but the machine shop I use seems really good a... Apr 24 2024, 08:38 PM
technicalninja
Are the basic AA heads worth a damn? The price i... Apr 24 2024, 09:20 PM
Zaffer I mainly asking in case one or both heads are crac... Apr 25 2024, 01:48 PM
Jack Standz Sorry to hear about your ankle. Hope you heal up ... Apr 25 2024, 05:25 PM
technicalninja I believe that the big guys (Raby/LN) are still mo... Apr 25 2024, 05:52 PM
r_towle I’m going to offer an idea.
Take the 2.0 liter o... Apr 25 2024, 08:54 PM
VaccaRabite
Take the 2.0 liter ... Apr 26 2024, 06:21 AM
Superhawk996
Finally, you can do a subi swap for about the sa... Apr 26 2024, 07:48 AM
Zaffer
Take the 2.0 liter... Apr 27 2024, 04:59 AM
Superhawk996
As for the other engine, it’s just a 1.8L lon... Apr 27 2024, 11:28 AM
Geezer914 The 914 is known for its handling. If you want it... Apr 26 2024, 10:28 AM
technicalninja Why are you limiting yourself with the factory int... Apr 27 2024, 11:25 AM
technicalninja :agree: :agree: :agree:
The stock FI is the si... Apr 27 2024, 01:17 PM
Zaffer I don’t know if the FI system I have is perfectl... Apr 27 2024, 05:49 PM
Superhawk996
My daughters don’t show a lot of interest when ... Apr 27 2024, 09:32 PM
Zaffer
[quote name='Zaffer' post='3141887' date='Apr 27 ... Apr 28 2024, 05:05 AM
Zaffer Well, I’m one step closer to starting back on my... May 1 2024, 01:53 PM
Geezer914 I used my Ljet injection when I built my 2056. I ... May 1 2024, 04:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:40 AM |
