> Blocking one wheel for valve adjustment., On a lift - how do YOU do it?
FlacaProductions
post Apr 25 2024, 04:38 PM
I get if you're doing valve adjustments by putting just one side of the car up but if you're on a lift (I have an EZCar Lift) it's a bit awkward for me to stop one wheel from turning (with my foot) while spinning the other to get to the next adjustment point.
Anyone use a ratchet strap or similar? Seems a floor jack under the wheel would just get pushed out of the way...
Thanks,
Brian
Geezer914
post Apr 25 2024, 04:43 PM
Geezer914
Nylon strap through the wheel and attached to something stationary.
FlacaProductions
post Apr 25 2024, 04:53 PM
QUOTE(Geezer914 @ Apr 25 2024, 03:43 PM) *
That's what I was thinking...just make double sure it's removed when you're done...
FlacaProductions   Blocking one wheel for valve adjustment.   Apr 25 2024, 04:38 PM
Root_Werks   Not for valve adjustments, but had good luck with ...   Apr 25 2024, 04:41 PM
infraredcalvin   I've jammed a jack in there, really just found...   Apr 25 2024, 04:42 PM
Geezer914   Nylon strap through the wheel and attached to some...   Apr 25 2024, 04:43 PM
FlacaProductions   Nylon strap through the wheel and attached to som...   Apr 25 2024, 04:53 PM
mgphoto   Pull the pin on the emergency brake cable on one w...   Apr 25 2024, 07:00 PM
GregAmy   https://www.napaonline.com/en/p/BK_7760022   Apr 25 2024, 07:07 PM
fiacra   https://www.napaonline.com/en/p/BK_7760022 Exac...   Apr 25 2024, 08:07 PM
technicalninja   :agree: :agree: I've been using one of thes...   Apr 25 2024, 07:45 PM
Spoke   I just used one of my ramps to stop the wheel. A c...   Apr 25 2024, 07:46 PM
FlacaProductions   I have one and use it but haven't felt it was ...   Apr 26 2024, 12:15 AM
ClayPerrine   I have one and use it but haven't felt it was...   Apr 26 2024, 11:26 AM
ChrisFoley   Iirc, a vice grip C clamp can be used to squeeze t...   Apr 26 2024, 04:13 AM
FlacaProductions   Understood - it just always seemed that it moved i...   Apr 26 2024, 11:37 AM
JamesM   Trans in 5th gear, I just grab one wheel with one ...   Apr 26 2024, 10:38 PM
rjames   Trans in 5th gear, I just grab one wheel with one...   Apr 27 2024, 01:10 PM
brant   Agree with Clay Remote starter Krusty method And ...   Apr 27 2024, 09:35 AM
FlacaProductions   Finally back to where the 914 is stored and got ba...   Apr 27 2024, 01:27 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:34 PM
