> Blocking one wheel for valve adjustment., On a lift - how do YOU do it?
FlacaProductions
post Apr 25 2024, 04:38 PM
I get if you're doing valve adjustments by putting just one side of the car up but if you're on a lift (I have an EZCar Lift) it's a bit awkward for me to stop one wheel from turning (with my foot) while spinning the other to get to the next adjustment point.
Anyone use a ratchet strap or similar? Seems a floor jack under the wheel would just get pushed out of the way...
Thanks,
Brian
technicalninja
post Apr 25 2024, 07:45 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
I've been using one of these for decades!
Sadly, modern cars often have no access to the starter anymore.
But modern cars often have a starter relay in the electrical junction box and with a couple of .250 spades you can get it done.
I have turned engines over via "in gear" and push the whole car but I've not turned one via the lock one wheel and turn the other wheel.
It should work fine!
I have found that if you have a vehicle that you cannot push by hand most of the time you CAN move it by rotating on the tire instead of pushing on the body.
I have moved 1-ton duallies around by myself using the "rotate the tires" trick.
For turning engines, once you've used a bump starter you never go back...
The one Greg linked to is decent and budget friendly.
I think I paid the same amount 30+ years ago!
FlacaProductions   Blocking one wheel for valve adjustment.   Apr 25 2024, 04:38 PM
Root_Werks   Not for valve adjustments, but had good luck with ...   Apr 25 2024, 04:41 PM
infraredcalvin   I've jammed a jack in there, really just found...   Apr 25 2024, 04:42 PM
Geezer914   Nylon strap through the wheel and attached to some...   Apr 25 2024, 04:43 PM
FlacaProductions   Nylon strap through the wheel and attached to som...   Apr 25 2024, 04:53 PM
mgphoto   Pull the pin on the emergency brake cable on one w...   Apr 25 2024, 07:00 PM
GregAmy   https://www.napaonline.com/en/p/BK_7760022   Apr 25 2024, 07:07 PM
fiacra   https://www.napaonline.com/en/p/BK_7760022 Exac...   Apr 25 2024, 08:07 PM
technicalninja   :agree: :agree: I've been using one of thes...   Apr 25 2024, 07:45 PM
Spoke   I just used one of my ramps to stop the wheel. A c...   Apr 25 2024, 07:46 PM
FlacaProductions   I have one and use it but haven't felt it was ...   Apr 26 2024, 12:15 AM
ClayPerrine   I have one and use it but haven't felt it was...   Apr 26 2024, 11:26 AM
ChrisFoley   Iirc, a vice grip C clamp can be used to squeeze t...   Apr 26 2024, 04:13 AM
FlacaProductions   Understood - it just always seemed that it moved i...   Apr 26 2024, 11:37 AM
JamesM   Trans in 5th gear, I just grab one wheel with one ...   Apr 26 2024, 10:38 PM
rjames   Trans in 5th gear, I just grab one wheel with one...   Apr 27 2024, 01:10 PM
brant   Agree with Clay Remote starter Krusty method And ...   Apr 27 2024, 09:35 AM
FlacaProductions   Finally back to where the 914 is stored and got ba...   Apr 27 2024, 01:27 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:00 PM
