| Boothy |
Jun 10 2024, 05:46 AM
Member ![]() ![]() Group: Members Posts: 116 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Morning All!
I can't seem to win against the leaking valve cover. Read the articles. Took it off yesterday. Cleaned the channel thoroughly. Laid a ton of the zinc stuff folks have mentioned out here -both sides. Let it sit for most of the day. Seemed ok for the first few then started again. Not a lot. Just enough to make the header smoke -and piss me off. 1.7 with new heads. Wondering if it's pressure? Bent cover? Maybe it's not the rocker cover and it's the push rod tube? I see some weld pieces into the cover. Just a daily driver. Thanks in advance! |
Garland Give these a try, working for me. There a bit thic... Jun 10 2024, 06:15 AM
Boothy Will do! Thank you! Jun 10 2024, 07:27 AM
930cabman I have always (50 years or so) installed VW type v... Jun 10 2024, 07:42 AM
FlacaProductions If you've read all the threads, you may have a... Jun 10 2024, 08:50 AM
windforfun Make sure it isn't bent in the slightest bit. ... Jun 10 2024, 09:24 AM
Boothy Thanks all!
I will try those suggestions. I... Jun 10 2024, 10:36 AM
fixer34 As you noted in the original post, are you SURE it... Jun 10 2024, 12:16 PM
Boothy
As you noted in the original post, are you SURE i... Jun 10 2024, 02:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 05:27 PM |
