Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,385 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
We are having an issue finding 50mm ducting (hose) to go from the "mouse ears" to the heater flapper. What we have is the rather inexpensive cardboard tubing available pretty readily. I am looking for something that is almost a plastic coated duct hose that would withstand dirt and possible....getting wet, and be able to keep clean. We have some in 60mm that is the finish we want, it's just too big.
We have searched high and low and came up scratch. I did find some 50mm plastic hose in the UK, but it only comes in 300mm/30cm (11.81 inches) lengths. I really need something that is 30 inches, 76.2cm or 762mm. Anyone have a suggestion? Thanks all, Michael (IMG:style_emoticons/default/beerchug.gif) |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Mack's hose is rated to 55c or 131F. Not high enough IMO for the application.
Running would work fine due to the cooling air but shutdown "heat soak" might hurt it. Bob's suggestion is a mere 1/32 of an inch too BIG. I didn't check heat rating on it (you should) but if a "tiny bit too big" won't work I'd be surprised. |
Lo-Fi Version | Time is now: 15th July 2025 - 03:54 AM |
