Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,385 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
We are having an issue finding 50mm ducting (hose) to go from the "mouse ears" to the heater flapper. What we have is the rather inexpensive cardboard tubing available pretty readily. I am looking for something that is almost a plastic coated duct hose that would withstand dirt and possible....getting wet, and be able to keep clean. We have some in 60mm that is the finish we want, it's just too big.
We have searched high and low and came up scratch. I did find some 50mm plastic hose in the UK, but it only comes in 300mm/30cm (11.81 inches) lengths. I really need something that is 30 inches, 76.2cm or 762mm. Anyone have a suggestion? Thanks all, Michael (IMG:style_emoticons/default/beerchug.gif) |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Seems to me there was a NAPA hose that was nearly identical to stock. I don't recall more than that.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Seems to me there was a NAPA hose that was nearly identical to stock. I don't recall more than that. I used the NAPA hose recently and it worked perfect. I will look around later and see if I can find anything. A search for this took me quite a while, and I might have saved the tag, somewhere. It took the guys at NAPA awhile to find it in their system, might be called "defroster hose" |
Lo-Fi Version | Time is now: 15th July 2025 - 04:28 AM |
