> GL-5, much better than GL-4
930cabman
post Jun 16 2024, 10:05 AM
Not sure how or why I had been running Sta-Lube GL-4 for the past several years ago, but I switched to Sta- Lube GL-5 this year and have a noticeable change.
Old gearbox and I have no idea of the state of repair, but a GL-5 change is a big (IMG:style_emoticons/default/beer.gif)
technicalninja
post Jun 16 2024, 10:16 AM
In what way has it been better?
GL4 is for manual transmissions that DO NOT have a differential in them.
GL4 does not have "extreme pressure" additives.
In a modern transmission the EP additives can coat the synchronizers and make them not work properly.
The differential NEEDS the EP stuff bigtime...
I wouldn't have thought you could feel the difference between the two.
I also would expect early diff failure without it. It's the hypoid gears that need it, not the bearings.
The early synchronizes seem to be less picky than the late ones.
Most of the late ones have 2 or 3 different brass pieces versus the original single synchronizers.
Late seem better IMO but don't work well with GL5.
porschetub
post Jun 16 2024, 10:50 PM
QUOTE(technicalninja @ Jun 17 2024, 04:16 AM) *
Confusing answers as OP is using the right oil as per Dr Evils recommendation ,not prepared to question what he says ....this guy has seen it all and is the best in the business ,cheers.
- Lo-Fi Version Time is now: 5th June 2025 - 04:43 AM
