NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,379 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
I am moving my fuel pump and drained the tank for the hose hook up etc. I looked deep inside and noticed a little residue on the bottom. I am going to pull the screen too, might be more there.
Is there something to use to flush the tank that is not fuel? This will be with the tank in place. I am NOT taking it out. Scope creep is killing me and I am already missing the best part of the driving season. |
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,007 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Removing the tank is one fastener on the strap & disconnecting the fuel lines I just wanted to add that the expansion tank needs to be removed BEFORE the tank comes out of it's mounted location. The reason is because the electrical plug is installed under it, and can not be disconnected until the expansion tank is removed. I recently forgot this fact when pulling the tank for my M/C install. My wiring harness was missing the actual electrical plug to the level sender when I got the car... and I'd always wondered how that happened. I spliced in a replacement though, and installed the tank etc. Then several weeks later while having to remove the tank again for the M/C install - I forgot to remove the expansion tank, and disconnect the electrical plug and ended up ripping my wiring splice(s), so I got to do that over again (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 8th July 2025 - 01:00 PM |
