| Halfnelson |
Jun 20 2024, 03:33 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Had a previous thread starting in 2022 about my 73 1.7 standard D-Jet running way too rich and flooding to the point where it wouldn't start. It's been an ongoing issue. I've had a go. 2 garages have had a go. I'm at the point where I'm beginning to lose hope.
A recap. Bought the car 2021, had a problem with intermittent flooding. So far have: Checked MPS - holding vacuum. Replaced CHT sensor and tested. Working when flooded. Replaced fuel pump and tested pressure. Replaced all vacuum hoses and tested for leaks. Valves set and rechecked. New 123 distributor. New injectors. Each time I think I've cracked it and it runs and drives - sometimes for a month or so. Then I'll go to start it and it'll flood again to the point where it contaminates the oil. I feel like I've never managed to get to the bottom of the problem. Just keep replacing parts. Thinking maybe a return line that intermittently blocks? I'm kind of at a loss. |
| Dave_Darling |
Aug 1 2024, 08:37 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I had an ECU that would open the injectors, but not close them. It was an intermittent problem at first, but then became more frequent as time went on. Apparently an output transistor failing can cause this.
I hydro-locked the engine trying to start it at one point. --DD |
| Halfnelson |
Aug 2 2024, 07:35 AM
I had an ECU that would open the injectors, but not close them. It was an intermittent problem at first, but then became more frequent as time went on. Apparently an output transistor failing can cause this. I hydro-locked the engine trying to start it at one point. --DD Thanks for the feedback, think I’ll try to source good replacements for ECU and MPS and go from there. If it’s the MPS it would be frustrating as it hold vacuum so that was one of the first things I’d taken off the list of potential culprits, but the feedback suggests they can still be bad so I was almost certainly too optimistic. |
| rjames |
Aug 2 2024, 10:21 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I had an ECU that would open the injectors, but not close them. It was an intermittent problem at first, but then became more frequent as time went on. Apparently an output transistor failing can cause this. I hydro-locked the engine trying to start it at one point. --DD Thanks for the feedback, think I’ll try to source good replacements for ECU and MPS and go from there. If it’s the MPS it would be frustrating as it hold vacuum so that was one of the first things I’d taken off the list of potential culprits, but the feedback suggests they can still be bad so I was almost certainly too optimistic. Another reason why you might want to change the ECU first and independently of the MPS: MPSs often need to be tuned to match the engine they are mated to. Any replacement MPS you get could run rich or lean before being tuned for your engine. I'm sure the experts like Jeff B. have seen it more often, but I can only remember one specific instance reported on this site where an MPS that held vacuum seemingly didn't operate correctly. |
| JeffBowlsby |
Aug 2 2024, 01:43 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,208 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
...but I can only remember one specific instance reported on this site where an MPS that held vacuum seemingly didn't operate correctly. I don't consider myself an expert but holding vacuum is only one of several conditions that can cause MPS failure. I have seen several erratic MPS behaviors, which may be vacuum related or not, all can be repaired if the fault can be isolated. BTW, for anyone trying this, using ones mouth to perform the vacuum test is completely ineffective. Use a real vacuum pump with a gauge. Other considerations: Fractured diaphragm Case/gasket/MPS plug/check valve leaks. Faulty coil electrically, or coils hanging up Distorted coil sheet springs Bad aneroid cell There may be additional issues not listed that effect the MPS function. These conditions may need attention or parts replacement when rebuilding an MPS, its typically not just a simple diaphragm and gasket replacement. Not all gaskets are in the kit, not all vacuum leaks are easy to locate. Often the MPS is opened-closed-reopened several times before it all works like it should. Also consider the time it takes just to open the case initially, remove the epoxy, tap all threaded holes, perform the calibration (which can take an hour or two sometimes even if you know what you are doing, especially if someone has messed with the original calibration before), and clean/paint the outer case when necessary. |
| Halfnelson |
Aug 5 2024, 08:35 AM
...but I can only remember one specific instance reported on this site where an MPS that held vacuum seemingly didn't operate correctly. I don't consider myself an expert but holding vacuum is only one of several conditions that can cause MPS failure. I have seen several erratic MPS behaviors, which may be vacuum related or not, all can be repaired if the fault can be isolated. BTW, for anyone trying this, using ones mouth to perform the vacuum test is completely ineffective. Use a real vacuum pump with a gauge. Other considerations: Fractured diaphragm Case/gasket/MPS plug/check valve leaks. Faulty coil electrically, or coils hanging up Distorted coil sheet springs Bad aneroid cell There may be additional issues not listed that effect the MPS function. These conditions may need attention or parts replacement when rebuilding an MPS, its typically not just a simple diaphragm and gasket replacement. Not all gaskets are in the kit, not all vacuum leaks are easy to locate. Often the MPS is opened-closed-reopened several times before it all works like it should. Also consider the time it takes just to open the case initially, remove the epoxy, tap all threaded holes, perform the calibration (which can take an hour or two sometimes even if you know what you are doing, especially if someone has messed with the original calibration before), and clean/paint the outer case when necessary. hi @JeffBowlsby - while I'm sourcing an ECU can I ask, if it does turn out to be the MPS is it possible to simply replace the MPS with a known good second hand MPS? I get the notion of rebuilding the original and then having to calibrate it, but would a fully functioning MPS not just plug in and improve things? Thanks |
Halfnelson Djet running way too rich... Still! Jun 20 2024, 03:33 AM
emerygt350 Have you removed the cold start valve from the equ... Jun 20 2024, 04:20 AM
Halfnelson
Have you removed the cold start valve from the eq... Jun 20 2024, 04:51 AM
JeffBowlsby The MPS holding vacuum is not a definitive test. ... Jun 20 2024, 06:01 AM
Halfnelson
The MPS holding vacuum is not a definitive test. ... Jun 20 2024, 06:31 AM
Halfnelson
The MPS holding vacuum is not a definitive test.... Jun 20 2024, 06:33 AM
JeffBowlsby
Also would that present as an intermittent issue... Jun 20 2024, 07:11 AM
Halfnelson
Also would that present as an intermittent issu... Jun 20 2024, 07:19 AM
JeffBowlsby
The MPS holding vacuum is not a definitive test.... Jun 20 2024, 07:10 AM
emerygt350 It could. Just depends on how it is cracked. I k... Jun 20 2024, 06:40 AM
emerygt350 If you get the rebuild kit from Chris it is super ... Jun 20 2024, 08:35 AM
StarBear
If you get the rebuild kit from Chris it is super... Jun 20 2024, 09:16 AM
emerygt350 I wonder about the ECU... They rarely go but perh... Jun 20 2024, 08:37 AM
rjames
I wonder about the ECU... They rarely go but per... Jun 20 2024, 09:10 AM
rjames double post Jun 20 2024, 09:10 AM
emerygt350 I have a known working extra 037 from my 73 2.0. ... Jun 20 2024, 09:15 AM
FlacaProductions What MPS do you currently have? I believe a 73 1.... Jun 20 2024, 09:34 AM
914_teener
What MPS do you currently have? I believe a 73 1... Jun 20 2024, 11:02 AM
emerygt350
What MPS do you currently have? I believe a 73 ... Jun 20 2024, 03:06 PM
JamesM
[quote name='914_teener' post='3152016' date='Jun... Jun 20 2024, 04:18 PM
Ishley It sounds a lot like you're having ignition a... Jun 20 2024, 11:55 AM
FlacaProductions Agreed on MPS tuning - that's a whole differen... Jun 20 2024, 12:47 PM
emerygt350 My point was, he could borrow my ECU. Jun 20 2024, 04:26 PM
JamesM
If you wa... Jun 20 2024, 09:45 PM
914_teener I'm with Jeff. This is a common failure mode o... Jun 20 2024, 10:01 PM
rjames The ECU is the easiest thing to test first. Move t... Jun 20 2024, 11:09 PM
emerygt350 The intermittent cht is an interesting idea but it... Jun 21 2024, 05:14 AM
ClayPerrine For years the rule of thumb was "The ECU neve... Jun 21 2024, 05:28 AM
JeffBowlsby While the idea of swapping in 'known good... Jun 21 2024, 05:32 AM
ClayPerrine
While the idea of swapping in 'known good... Jun 21 2024, 07:19 AM
emerygt350 If cost is no issue, definitely send it out for te... Jun 21 2024, 06:31 AM
emerygt350 Just a quick mention on the TPS, although I really... Jun 21 2024, 06:33 AM
dr914@autoatlanta.com substitution is your friend. That is what we do he... Jun 21 2024, 08:22 AM
Halfnelson Thanks so much for the suggestions. I’ve been th... Jun 22 2024, 04:27 AM
Halfnelson I’m not sure if this is relevant but when it doe... Jun 22 2024, 04:32 AM
ClayPerrine
I’m not sure if this is relevant but when it do... Jun 22 2024, 04:39 AM
emerygt350 Ahh, Cornwall, just noticed that.
Can you descr... Jun 22 2024, 04:53 AM
Halfnelson Although the cht has been changed and I’ve teste... Jun 22 2024, 05:13 AM
ClayPerrine
Although the cht has been changed and I’ve test... Jun 22 2024, 06:27 AM
technicalninja What he's describing appears to be fuel foulin... Jun 22 2024, 03:47 PM
technicalninja Made me think...
An ECU that did short the inject... Jun 22 2024, 03:59 PM
emerygt350 Pressure Regulator on these is static. The wet pl... Jun 22 2024, 04:03 PM
Halfnelson Do you recommend pulling a plug, checking, and the... Jun 23 2024, 05:08 AM
emerygt350 Yeah, check first and then after if it doesn't... Jun 23 2024, 06:01 AM
Halfnelson OK, a quick update on the richness / flooding / no... Aug 1 2024, 11:54 AM
914_teener
OK, a quick update on the richness / flooding / n... Aug 1 2024, 12:34 PM
Halfnelson
My car did this when I first got it.
An MPS b... Aug 1 2024, 02:03 PM
Ishley Somehow you’re getting too much fuel. Have you t... Aug 1 2024, 12:06 PM
ClayPerrine Have you checked the cold start injector to see if... Aug 1 2024, 01:40 PM
emerygt350 That intermittent rich makes me think MPS as well.... Aug 1 2024, 03:50 PM
rjames MPS or ECU.
These are the exact symptoms I had an... Aug 1 2024, 03:59 PM
JeffBowlsby Of course, that should work and ideally it should ... Aug 5 2024, 08:51 AM
Halfnelson
Of course, that should work and ideally it should... Aug 5 2024, 10:04 AM
Halfnelson Got a package in the post yesterday from the US wi... Aug 22 2024, 12:03 AM
ctc911ctc Jeff is the best - and despite his modesty, he IS ... Aug 22 2024, 07:01 AM
Halfnelson
Jeff is the best - and despite his modesty, he IS... Aug 22 2024, 08:54 AM
StarBear Yay!! :Qarl: Aug 22 2024, 06:20 AM
rjames :beer2: Aug 22 2024, 08:28 AM
JeffBowlsby Happy Daze! Glad to have helped. Aug 22 2024, 09:33 AM
GregAmy Anyone with D-Jet that has not replaced the diaphr... Aug 22 2024, 09:57 AM
emerygt350 Excellent news! Aug 22 2024, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 09:25 PM |
