> OT: coolant leak x35d
seanpaulmc
post Aug 17 2024, 11:43 AM
OT so if not appropriate here please move
2017 x35d X5 BMW
~61K
3.0 turbo diesel
Bad engine coolant leak
It’s not a drip, drip, drip. Good flow.
Not up front so doesn’t appear to be radiator.
Near firewall.
Anyone have experience with similar?
Thanks,
Sean
Superhawk996
post Aug 17 2024, 11:55 AM
BMW notorious for leaking coolant pipes. Often made of plastic - cracks. O-rings get nicked or degraded though yours isn’t that old. Metal retention clips fail or don’t get clipped properly.
No easy answer other than de-trim the belly pans if necessary to figure out where leak is coming from.
2012 x5 35d ~ 140k miles. Like the ride / handling but hate the complexity of the vehicle. Not DIY friendly (IMG:style_emoticons/default/happy11.gif)
porschetub
post Aug 17 2024, 06:31 PM
QUOTE(Superhawk996 @ Aug 18 2024, 05:55 AM) *
(IMG:style_emoticons/default/agree.gif) thermostat housing are really bad the one in my E39 2001 touring failed after 60k miles,leaked down the front of the motor and took out the crank sensor which wasn't even a sealed unit ,car went into limp mode .
Ordered a new housing and the guy told me that BMW used recycled plastic ,he mentioned he stopped selling the genuine part as he had history of repeated failures the german made aftermarket one he sold me had never given issues .
It's not only water fittings that fail my oil separator went and cracked it seemed clear that the plastic was no good with oil either ,I had huge issues with this car and ended selling it after constant repairs to keep it going and dumped a ton of $$$ just to move it on despite being a dealer serviced approved used car (IMG:style_emoticons/default/WTF.gif) .
To the OP be prepared to suffer BMW's version of assembly , any repairs are a sequence of removing many parts to get to the issue , hope you have a hoist ?? problem is BMW don't really want you to fix this easily and burn you for parts also.
Hope you sort it , good luck,cheers
- Lo-Fi Version Time is now: 12th March 2026 - 08:04 AM
