| SKL1 |
Aug 19 2024, 06:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,765 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Finally getting ready to send my '71 I've had since new to the restoration boys at Stalltek for paint and six conversion work.
I've never figured out the search function so would like opinions on the best bulkhead engine mount options- want a factory look and will be doing a mild 2.4 E engine build. The car has already been converted to a side shifter some 30 years ago... getting the sheet metal I got here on a group buy powdercoated as we speak. Have at it guys... |
| ClayPerrine |
Aug 20 2024, 05:18 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I would agree with the above if you are staying with a small six. But you need to consider that you may want a bigger engine in the future. If you do, you want the stronger motor mount.
The Naroescape mount is really good, as is the Rich Johnson mount. |
| mepstein |
Aug 20 2024, 06:14 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I would agree with the above if you are staying with a small six. But you need to consider that you may want a bigger engine in the future. If you do, you want the stronger motor mount. The Naroescape mount is really good, as is the Rich Johnson mount. I’ll be using the maddog oem replica for a built 3.4 engine. I’ve already seen it in place on a hot 3.0 (300 hp on a Peter Dawe built engine) I tried the Naroescape mount. No bueno. Eventually I will remove it from my car and make the tin and everything fit properly bum not the first one to have problems with that mount but it sure was frustrating. Stronger is sort of a relative term. Has the oem mount proven to be inadequate for big engines or is that just your perception. I have seen big engines in real sixes without issues. Some of them get flogged pretty hard on the track. The nice thing about an oem style mount is everything fits the way it should. |
| Superhawk996 |
Aug 20 2024, 06:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,732 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I tried the Naroescape mount. No bueno. Eventually I will remove it from my car and make the tin and everything fit properly bum not the first one to have problems with that mount but it sure was frustrating. The nice thing about an oem style mount is everything fits the way it should. Stronger is sort of a relative term. ![]() Translation: the engine doesn’t fit right . . . But that’s normal. The OEM mount also locates on the bulkhead where there is internal structure to support it rather than just hanging off a layer of sheetmetal that is unsupported. NVH will be better with the OEM mount and OEM rubber isolation (i.e. less in cabin noise and vibration ) Nice that the OEM rubber isolation is now being reproduced. |
SKL1 Best bulkhead mount options? Aug 19 2024, 06:26 PM
mate914 A smaller engine like yours, defiantly get the ori... Aug 19 2024, 07:00 PM
brant Agreed
You want the right original look
Stock or... Aug 19 2024, 07:23 PM
FlacaProductions Oooh Stalltek. Looking forward to updates through ... Aug 19 2024, 09:20 PM
Shivers Only thing I have to share is Congratulations :) Aug 19 2024, 10:13 PM
mepstein My pick for best one. Aug 20 2024, 04:35 AM
Root_Werks
I used the MD mount and r... Aug 20 2024, 10:31 AM
mb911
Just keep in mind that d... Aug 21 2024, 05:22 AM
930cabman
I used this one, worked f... Aug 21 2024, 04:01 PM
[quote name='mepstein' post='3162982' date='Aug 2... Aug 20 2024, 09:41 AM
ClayPerrine I do not like the fact that the front of the motor... Aug 20 2024, 08:09 AM
Superhawk996 Keep in mind OP is running a 2.4L
High HP brings... Aug 20 2024, 09:18 AM
ClayPerrine
High HP bring... Aug 21 2024, 05:12 AM
dr914@autoatlanta.com agree with Matt, get the original setup, we get th... Aug 20 2024, 09:48 AM
NARP74 What is the difference between the 2 MD mount opti... Aug 20 2024, 09:59 AM
What is the difference between the 2 MD mount opt... Aug 20 2024, 11:42 AM
live free & drive Just for some tight numbers onthe Naro mount; if ... Aug 20 2024, 01:22 PM
Just for some tight numbers onthe Naro mount; if... Aug 20 2024, 02:20 PM
Superhawk996
Just for some tight numbers onthe Naro mount; i... Aug 20 2024, 03:27 PM
[quote name='mepstein' post='3163068' date='Aug 2... Aug 20 2024, 06:44 PM
rgalla9146 I never liked aftermarket mounts because they all ... Aug 21 2024, 07:35 AM
burton73
I never liked aftermarket mounts because they all... Aug 27 2024, 05:58 PM
Cairo94507 I am not sure where I heard this, but it is my und... Aug 21 2024, 07:44 AM
Superhawk996
I am not sure where I heard this, but it is my un... Aug 21 2024, 08:20 AM
930cabman
[quote name='Cairo94507' post='3163197' date='Aug... Aug 27 2024, 05:43 PM
gms I have been racing my car for 15 seasons with the ... Aug 21 2024, 09:48 AM
Superhawk996
I have been racing my car for 15 seasons with the... Aug 22 2024, 07:43 AM
gms also have been using URO HD engine mount (top) for... Aug 21 2024, 09:56 AM
live free & drive Has anybody used the chassis mount from Mittelmoto... Aug 27 2024, 01:30 PM
930cabman
Has anybody used the chassis mount from Mittelmot... Aug 27 2024, 05:45 PM
sixnotfour Factory mount Complete and factory914-6 sheet meta... Aug 29 2024, 11:01 AM
Superhawk996
Factory mount Complete and factory914-6 sheet met... Aug 29 2024, 12:27 PM
mepstein The RD tin is really nice if you want the original... Aug 29 2024, 12:43 PM
mb911
The RD tin is really nice if you want the origina... Aug 29 2024, 01:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 09:02 AM |
