> 911 hand brake install on 914, best caliper ?,
rgalla9146
post Aug 21 2024, 06:01 PM
I'm installing 911 emergency brakes on my 914 trailing arms.
What is the best rear caliper to go with ?
Must be compatible (piston size) with S alloy fronts and 19mm master.
Must have supply and bleeder in correct orientation and vented 911 rotor
compatible.
Is there a suitable alloy caliper available ?
Help / suggestion is appreciated.
Rory
rgalla9146
post Aug 22 2024, 05:33 AM
Thanks for all the replies.
I'm installing the 911 ebrakes for a simple reason.
My headers are much wider than stock heat exchangers and the stock
ebrake cables can not be held away from the hot tubes.
With the 911 ebakes the cables can be repositioned.
I'll post pics as it comes together.
I do have M calipers and will use them.
I was hoping there might be some suitable little known alloy rears.
Different subject. Does anyone have a pair of PMB alloy 914 6 rears for sale ?
I'd like them for another project and do have stock 6 rears for bait.
- Lo-Fi Version Time is now: 25th May 2026 - 04:01 PM
