| Garland |
Aug 24 2024, 08:47 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I wanted to set of speakers in the factory pods, without hacking anything up, hoping for a little better sound than the 50-year-old paper, torn speakers.
![]() Omega 4 x 6 dual cone BU-46.7 my local speaker store says you can still order them, if they’re out of stock. ![]() They look good except for the bright gold medal that will be seen through the grill ![]() Also, they ride too high in the housing due to not clearing the factory mounts ![]() I marked, the speaker where they need to be trimmed, and with some help from the clippers, done. ![]() Now they clear the posts, and Mount flush. ![]() Here’s the view from the front side, that doesn’t look that great ![]() So after cleaning the metal well, so paint will adhere. ![]() |
| Garland |
Aug 24 2024, 08:54 AM
Time to do a little masking, with a piece of cardboard and a hose clamp to hold it in place
![]() First coat of paint on, then second coat ![]() Once dry very flat in finish. ![]() Then using some very thin, almost stretchy material. ![]() I set it in the housing using the more reflective side of the material. I used the original clips to hold the speakers in place. If the ones you have don’t work, you can bend some strap steel, and add a hole to it for the screw. ![]() ![]() A little black cloth tape to hold it in place ![]() And they look, and believe it or not, even sound very good. I’m using a vintage blaupunkt head unit, pushing a big 7 watts. ![]() |
Garland Speakers that fit with no mod to factory housings Aug 24 2024, 08:47 AM
Literati914 Nice work. I like the cloth trick. Were those spea... Aug 24 2024, 10:47 PM
Garland
Nice work. I like the cloth trick. Were those spe... Aug 25 2024, 12:39 PM
chmillman I used a slightly different approach to mounting s... Aug 25 2024, 03:25 AM
burton73 @chmillman
I have done a few of these speaker mo... Aug 25 2024, 08:40 AM
chmillman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2024, 09:25 AM
technicalninja
I used a slightly different approach to mounting ... Aug 25 2024, 11:24 AM
chmillman Here are 2D CAD (DXF) files for the laser cutting.... Aug 27 2024, 03:30 AM
chmillman Added a Pioneer TS-WX010A subwoofer inside the sto... Sep 3 2024, 10:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 31st May 2026 - 06:15 AM |
