| Mike1981 |
Aug 4 2024, 11:14 AM
Member ![]() ![]() Group: Members Posts: 281 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
| iankarr |
Sep 1 2024, 11:46 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I made one from some cork gasket material. Pretty straightforward and if you mess up, it's only a sheet of cork (IMG:style_emoticons/default/wink.gif)
| Superhawk996 |
Sep 1 2024, 11:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,845 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I made one from some cork gasket material. Pretty straightforward and if you mess up, it's only a sheet of cork (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/agree.gif) But unless I misunderstand the post, I think the spring inside his cap is broken, necessitating a new (used) cap? |
| Mike1981 |
Sep 1 2024, 11:58 AM
I made one from some cork gasket material. Pretty straightforward and if you mess up, it's only a sheet of cork (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/agree.gif) But unless I misunderstand the post, I think the spring inside his cap is broken, necessitating a new (used) cap? Someone did mention this. I could not see a spring in my cap is it under the cork gasket? |
| Superhawk996 |
Sep 1 2024, 12:20 PM
Someone did mention this. I could not see a spring in my cap is it under the cork gasket? Don’t worry about seeing the spring. What important is that the flat area where the gasket sits moves back and forth with spring pressure on it to force the gasket into contact with the filler inlet ![]() |
| Mike1981 |
Sep 1 2024, 12:27 PM
Someone did mention this. I could not see a spring in my cap is it under the cork gasket? Don’t worry about seeing the spring. What important is that the flat area where the gasket sits moves back and forth with spring pressure on it to force the gasket into contact with the filler inlet ![]() Mine is exactly like this one.... broken spring. Can I buy a spring or would it be better to buy a new cap? Does anyone have one to sell? Thanks |
Mike1981 Gas Cap Gasket Aug 4 2024, 11:14 AM
914sgofast2 Try 914Rubber.com or AutoAtlanta.com Aug 4 2024, 11:23 AM
Mike1981 thanks Aug 4 2024, 11:39 AM
bdstone914
Hello Everyone
I tried to use the search functio... Aug 4 2024, 06:21 PM
Mike1981
Hello Everyone
I tried to use the search functi... Aug 5 2024, 04:19 PM
bdstone914 The spring is not visible. Press down on the cent... Aug 5 2024, 04:50 PM
76-914 I bought one from 914rubber since I had just insta... Aug 4 2024, 06:37 PM
bdstone914 This one had a broken spring. See how far down the... Aug 5 2024, 05:09 PM
Mike1981
This one had a broken spring. See how far down th... Aug 5 2024, 05:19 PM
Mike1981
This one had a broken spring. See how far down t... Sep 1 2024, 11:12 AM
Mike1981 Hello Everyone.
I purchased a new gasket...no imp... Sep 1 2024, 11:23 AM
Superhawk996 First - stop overfilling the tank
Second route h... Sep 1 2024, 11:24 AM
Mike1981
Second route ... Sep 1 2024, 11:29 AM
Superhawk996 I wouldn’t worry about trying to tie together in... Sep 1 2024, 11:43 AM
fiacra Not to speak for other posters, but the gist of wh... Sep 1 2024, 11:44 AM
Superhawk996 Use the easy button buy a used cap.
AA lists th... Sep 1 2024, 12:31 PM
Mike1981
AA lists t... Sep 1 2024, 12:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 10:39 PM |
