> 914-6 webers don't fully open, Help!!!
si2t3m
post Jun 3 2003, 08:27 AM
914 addict
I never really checked if the webers were fully opened at WOT. Guess what, they are not!
A little less that 1/4 travel is left to get the throttle plates fully straight. DOH!!! It accelerates fine but it could accelerate faster!!! (IMG:style_emoticons/default/smile.gif)
Drop links from the crossbar to the carbs are nice & tight and are in sync @ 1000rpm and also at 4000rpm, so i'm figuring it's either some ajustement in the rod between the crossbar & the bellcrank on the engine or the rod between the bellcrank on the engine and the tranny or the ajustement on the throttle cable end at the tranny.
I'm just not sure from what end i should start to playing with the linkage It seems like i'm running out of travel at the bellcrank on the tranny.
Any basic things i should check before playing around with the linkage???
TIA
Marc-André
si2t3m
post Jun 3 2003, 09:23 AM
914 addict
I took the end of the crossbar were it connects to the rod going to the bellcrank on the engine/carb manifold and pulled on it.
Webers go to full open.
There seems to be some slack somewhere or the geometry is off between the throttle cable and the bellcrank on the tranny.
When i press the pedal, i can feel alot of resistance in the last part of the pedal travel. Like if it wanted to bend the rod between the tranny & the engine. So it doesn't seem like the pedal is limiting the travel. It's binding somewhere else.
I'll go outside during lunch & report the position of the different components. (crossbar, bellcrank at the engine end and bellcrank at the tranny).
Might be more obvious after looking closely on what is going on.
Marc-André
si2t3m   914-6 webers don't fully open   Jun 3 2003, 08:27 AM
Lawrence914-6   Okay... are you sure the linkage is limiting your ...   Jun 3 2003, 08:43 AM
fuch toy   Disconnect linkage, try to open carbs by hand........   Jun 3 2003, 08:50 AM
Lawrence914-6   I hate to disagree with Zois, as he has much more ...   Jun 3 2003, 08:57 AM
fuch toy   Welllllll.....it worked on 3.6 install......   Jun 3 2003, 09:06 AM
Lawrence914-6   I'm sure you're right, Mike. Maybe the pe...   Jun 3 2003, 09:10 AM
si2t3m   I took the end of the crossbar were it connects to...   Jun 3 2003, 09:23 AM
brant   marc'-andre, If I'm remembering correctl...   Jun 3 2003, 09:31 AM
fuch toy   I still think you need to check for a stop under t...   Jun 3 2003, 09:31 AM
Lawrence914-6   I don't have my car here... so I'm going f...   Jun 3 2003, 09:34 AM
si2t3m   Yes it's a conversion. I'm running a /6 ...   Jun 3 2003, 09:40 AM
djm914-6   Can someone please explain WOT? I asked my mechani...   Jun 3 2003, 10:10 AM
Lawrence914-6   I've never checked WOT on my carbs. I have no...   Jun 3 2003, 10:13 AM
mskala
- Lo-Fi Version Time is now: 3rd July 2025 - 03:46 AM
