> 914-6 webers don't fully open, Help!!!
si2t3m
post Jun 3 2003, 08:27 AM
914 addict
I never really checked if the webers were fully opened at WOT. Guess what, they are not!
A little less that 1/4 travel is left to get the throttle plates fully straight. DOH!!! It accelerates fine but it could accelerate faster!!! (IMG:style_emoticons/default/smile.gif)
Drop links from the crossbar to the carbs are nice & tight and are in sync @ 1000rpm and also at 4000rpm, so i'm figuring it's either some ajustement in the rod between the crossbar & the bellcrank on the engine or the rod between the bellcrank on the engine and the tranny or the ajustement on the throttle cable end at the tranny.
I'm just not sure from what end i should start to playing with the linkage It seems like i'm running out of travel at the bellcrank on the tranny.
Any basic things i should check before playing around with the linkage???
TIA
Marc-André
fuch toy
post Jun 3 2003, 09:31 AM
Unregistered
I still think you need to check for a stop under the pedal....you don't have to take it ALL off, mine needed too, but pull the pedal and if there IS a stop and take a 1/2 inch off at a time...untill the full opening of the butterflies are achieved....
si2t3m   914-6 webers don't fully open   Jun 3 2003, 08:27 AM
Lawrence914-6   Okay... are you sure the linkage is limiting your ...   Jun 3 2003, 08:43 AM
fuch toy   Disconnect linkage, try to open carbs by hand........   Jun 3 2003, 08:50 AM
Lawrence914-6   I hate to disagree with Zois, as he has much more ...   Jun 3 2003, 08:57 AM
fuch toy   Welllllll.....it worked on 3.6 install......   Jun 3 2003, 09:06 AM
Lawrence914-6   I'm sure you're right, Mike. Maybe the pe...   Jun 3 2003, 09:10 AM
si2t3m   I took the end of the crossbar were it connects to...   Jun 3 2003, 09:23 AM
brant   marc'-andre, If I'm remembering correctl...   Jun 3 2003, 09:31 AM
fuch toy   I still think you need to check for a stop under t...   Jun 3 2003, 09:31 AM
Lawrence914-6   I don't have my car here... so I'm going f...   Jun 3 2003, 09:34 AM
si2t3m   Yes it's a conversion. I'm running a /6 ...   Jun 3 2003, 09:40 AM
djm914-6   Can someone please explain WOT? I asked my mechani...   Jun 3 2003, 10:10 AM
Lawrence914-6   I've never checked WOT on my carbs. I have no...   Jun 3 2003, 10:13 AM
mskala
- Lo-Fi Version Time is now: 3rd July 2025 - 03:19 AM
