| technicalninja |
Sep 30 2024, 09:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
While cruising through Arnie's post project thread a comment he posted made me do a bit of searching.
Arnie's thread: http://www.914world.com/bbs2/index.php?showtopic=320359 What my search for "Toyota head light kit" revealed was this https://cruiserteq.com/oem-toyota-koito-h4-...s-elec81110kit/ That shows a pair of "OEM" glass 7" housings, H4 bulbs, and what looks like a pretty nice harness with relays. For $42.50... Hands down this is the least expensive route to glass housing H4 set up. If the parts are actually made in Japan, the quality will be excellent. I'd order today if I hadn't already solved my headlight gathering with a used 914Rubber LED kit. The glass H4 housings individually are often more than that whole kit. One of the more common LED replacement bulbs is for the H4. Hope this helps someone... |
| technicalninja |
Oct 1 2024, 04:42 PM
Other projects...
I have multiple irons in the fire! I'm more Vintage Rice than Vintage Schnapps. (IMG:style_emoticons/default/ninja.gif) |
technicalninja Inexpensive glass H4 head light kit Sep 30 2024, 09:21 PM
technicalninja I decided to take my own advice and order two kits... Sep 30 2024, 09:37 PM
87m491 I was alerted to this deal a bit ago. I think I g... Oct 1 2024, 06:48 AM
mb911 Those would be a great option. My setup is from a ... Oct 1 2024, 04:24 AM
chmillman Just beware of two things: beam distribution/qual... Oct 1 2024, 07:54 AM
technicalninja Arnie advised housings available direct from Toyot... Oct 1 2024, 11:10 AM
DC_neun_vierzehn
Arnie advised housings available direct from Toyo... Oct 1 2024, 01:02 PM
87m491 They look like this.
http://www.914world.com/bbs2/... Oct 1 2024, 01:26 PM
jbyron Just ordered a set from my local toyota dealer. No... Oct 1 2024, 02:03 PM
technicalninja I'm dying to see just what's in the harnes... Oct 1 2024, 02:14 PM
chmillman Not sure why you would need additional relays - at... Oct 1 2024, 03:31 PM
87m491
Not sure why you would need additional relays - a... Oct 1 2024, 06:06 PM
mepstein A couple years ago, I was using my 914-4 as a dail... Oct 1 2024, 06:17 PM
technicalninja I'm planning on running LEDs if I can find a H... Oct 2 2024, 08:12 AM
L-Jet914 I'm surprised Toyota still sells something thi... Oct 3 2024, 12:00 AM
technicalninja Covered fuses!
There's two of them and tw... Oct 3 2024, 08:19 AM
Artfrombama What were these designed for? All that comes to mi... Oct 3 2024, 08:38 AM
L-Jet914
What were these designed for? All that comes to m... Oct 3 2024, 09:49 PM
JmuRiz Wow, I guess I should have sold my Hella H4s a cou... Oct 3 2024, 08:51 AM
anderssj I picked up one of these kits last spring. I'm... Oct 4 2024, 09:49 AM
technicalninja
There's no physical interference (at least o... Oct 4 2024, 12:22 PM
Literati914 I have a set on order.. I called two local dealers... Oct 4 2024, 02:46 PM
L-Jet914
I have a set on order.. I called two local dealer... Oct 4 2024, 07:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:29 AM |
