> Inexpensive glass H4 head light kit
technicalninja
post Sep 30 2024, 09:21 PM
While cruising through Arnie's post project thread a comment he posted made me do a bit of searching.
Arnie's thread: http://www.914world.com/bbs2/index.php?showtopic=320359
What my search for "Toyota head light kit" revealed was this
https://cruiserteq.com/oem-toyota-koito-h4-...s-elec81110kit/
That shows a pair of "OEM" glass 7" housings, H4 bulbs, and what looks like a pretty nice harness with relays.
For $42.50...
Hands down this is the least expensive route to glass housing H4 set up.
If the parts are actually made in Japan, the quality will be excellent.
I'd order today if I hadn't already solved my headlight gathering with a used 914Rubber LED kit.
The glass H4 housings individually are often more than that whole kit.
One of the more common LED replacement bulbs is for the H4.
Hope this helps someone...
technicalninja
post Oct 3 2024, 08:19 AM
Covered fuses!
There's two of them and two relays.
The harness is as "plug and play" as you could make it.
It plugs into both new lights and has a socket that a single headlight connector, from the original vehicles wiring system, plugs into.
A simple power source and ground are the other two connections.
It's designed for a front engine/battery in E-compartment but could be adapted to almost anything.
When I did the "snow melters" in my customers 73 240z this wiring was the only difficult part of the job.
This harness that comes with the kit as a value of $100 IMO!
I'm in agreement with @L-Jet914 .
The bulbs that come with this kit will be normal strength as for output, but they will live FOREVER!!!!
The bulb are slightly curved., almost flat and might cause a fitment issue in a 914 as they stick out farther than I would like.
When I get time, I'll stick one in my car to see how much they protrude from the beauty covers...
They are glass/ceramic construction so the r3eflective surface appears to be real chrome.
The newer plastic housing lights have what I call "fake chrome" reflectors that can fad quickly with age.
technicalninja   Inexpensive glass H4 head light kit   Sep 30 2024, 09:21 PM
technicalninja   I decided to take my own advice and order two kits...   Sep 30 2024, 09:37 PM
87m491   I was alerted to this deal a bit ago. I think I g...   Oct 1 2024, 06:48 AM
mb911   Those would be a great option. My setup is from a ...   Oct 1 2024, 04:24 AM
chmillman   Just beware of two things: beam distribution/qual...   Oct 1 2024, 07:54 AM
technicalninja   Arnie advised housings available direct from Toyot...   Oct 1 2024, 11:10 AM
DC_neun_vierzehn   Arnie advised housings available direct from Toyo...   Oct 1 2024, 01:02 PM
87m491   They look like this. http://www.914world.com/bbs2/...   Oct 1 2024, 01:26 PM
jbyron   Just ordered a set from my local toyota dealer. No...   Oct 1 2024, 02:03 PM
technicalninja   I'm dying to see just what's in the harnes...   Oct 1 2024, 02:14 PM
chmillman   Not sure why you would need additional relays - at...   Oct 1 2024, 03:31 PM
87m491   Not sure why you would need additional relays - a...   Oct 1 2024, 06:06 PM
technicalninja   Other projects... I have multiple irons in the fi...   Oct 1 2024, 04:42 PM
mepstein   A couple years ago, I was using my 914-4 as a dail...   Oct 1 2024, 06:17 PM
technicalninja   I'm planning on running LEDs if I can find a H...   Oct 2 2024, 08:12 AM
L-Jet914   I'm surprised Toyota still sells something thi...   Oct 3 2024, 12:00 AM
technicalninja   Covered fuses! There's two of them and tw...   Oct 3 2024, 08:19 AM
Artfrombama   What were these designed for? All that comes to mi...   Oct 3 2024, 08:38 AM
L-Jet914   What were these designed for? All that comes to m...   Oct 3 2024, 09:49 PM
JmuRiz   Wow, I guess I should have sold my Hella H4s a cou...   Oct 3 2024, 08:51 AM
anderssj   I picked up one of these kits last spring. I'm...   Oct 4 2024, 09:49 AM
technicalninja   There's no physical interference (at least o...   Oct 4 2024, 12:22 PM
Literati914   I have a set on order.. I called two local dealers...   Oct 4 2024, 02:46 PM
L-Jet914   I have a set on order.. I called two local dealer...   Oct 4 2024, 07:33 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:29 AM
