Ouch, why do rear vented rotors cost so much??, bitten by the 4-piston caliper bug :) |
Mueller |
Feb 2 2005, 11:23 AM
closed the deal last night for 2 pairs of 4-piston calipers for $200....designed for 22mm rotors, but I see no reason why they won't be okay with the 911 20mm rotors...now to go break into someones garage and get a pair of the billet 4-lug hubs
now back to the rotors.....PP has the fronts for $48 and the rears are $72 each...I guess one good thing is that one normally goes thru front rotors faster than rear rotors...we shall see.... |
ArtechnikA |
Feb 2 2005, 11:34 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
because while the fronts are relatively shallow, and bolt to the hub, the rears are fairly deep, and incorporate a fairly thick and concentrically machined brake drum for the parking / e-brake.
i think i'd take advantage of the thickness differential to run some of those titanium pad insulators, but that's just me. 911 rear brakes have the "opportunity" to do a bigger share of the work since the back is already a lot heavier to start with ... |
Lo-Fi Version | Time is now: 8th June 2024 - 12:48 PM |
