> Question about early vs. late tops
DC_neun_vierzehn
post Dec 7 2024, 02:07 PM
I know there are two different tops (early vs. late).
My question is can an early top work on a late car IF the rubber seals on the sides have been updated (to match the late windows) AND the bump stops have been swapped (to match the late latches)?
The reason I ask is that I have two spare tops (one early and one late). I have them both stripped down (no rubber, no hardware, no felt headliner, etc.). Just the fiberglass top. And I noticed that the early top much lighter. I weighed them and the early top is approx. 17 pounds whereas the late top is approx. 23 pounds.
I'm not looking to shed weight for performance (although that's a bonus), but a lighter top would be less cumbersome to take off and put on the car.
TIA
-Kris
post Dec 7 2024, 06:19 PM
Resident German
More than you ever wanted to know.
http://www.914world.com/bbs2/index.php?showtopic=73129
DC_neun_vierzehn
post Dec 7 2024, 06:45 PM
QUOTE(SirAndy @ Dec 7 2024, 07:19 PM) *
Thank you. I’ve read that post a few time before as well as other posts on this topic. I have more questions than answers every time after reading that post, sadly. I’m hoping someone has tried this before and can answer my question yes or no from personal experience.
post Dec 7 2024, 08:21 PM
Resident German
QUOTE(DC_neun_vierzehn @ Dec 7 2024, 04:45 PM) *
Post #11 in that thread:
"I've got a late top and early windows and it does not seal right at all.
The top should match the windows ..."
Not only are the seals different, the actual mounting points of the seals is different too. So even if you used the seals that are correct for your windows they still won't seal well if used on a top that doesn't match the windows.
And yes, i'm talking about the windows and not the car manufacturing year. Because people can (and do) mismatch doors and windows.
Your top and seals need to match the year of the doors and windows of your car.
PS: And to make it even more complicated, as explained in that thread linked, '73 is a transition year for the doors and windows. See post #29 in the thread linked.
JamesM
post Dec 7 2024, 09:21 PM
QUOTE(SirAndy @ Dec 7 2024, 07:21 PM) *
Are you sure about this? Ill have to go compare parts again but...
The front window channel is the same between early and late cars as is the rear window seal so the height of the window should be the same.
Also Porsche superseded the early part with the late and even specified that the late roof to window seals work on the early cars. The rear seal fits differently but the side seals don't. Both these things lead me to believe side seal mismatch is not the issue.
In my experience as long as the rear rubber blocks match the style of rear Targa latches you have, and the window position is adjusted properly, I have not had an issue swapping tops between years.
DC_neun_vierzehn   Question about early vs. late tops   Dec 7 2024, 02:07 PM
930cabman   :popcorn:   Dec 7 2024, 02:52 PM
DC_neun_vierzehn   :popcorn: One of the things I’ve loved about ...   Dec 7 2024, 05:48 PM
Robarabian   That reply was pretty normal actually... someone i...   Dec 7 2024, 06:44 PM
930cabman   :popcorn: One of the things I’ve loved about...   Dec 8 2024, 02:01 PM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3180689' dat...   Dec 8 2024, 02:45 PM
930cabman   [quote name='DC_neun_vierzehn' post='3180689' da...   Dec 8 2024, 03:36 PM
SirAndy   More than you ever wanted to know. http://www.914w...   Dec 7 2024, 06:19 PM
DC_neun_vierzehn   More than you ever wanted to know. http://www.914...   Dec 7 2024, 06:45 PM
SirAndy   [quote name='SirAndy' post='3180693' date='Dec 7 ...   Dec 7 2024, 08:21 PM
JamesM   Not only are the seals different, the actual mou...   Dec 7 2024, 09:21 PM
SirAndy   Not only are the seals different, the actual mo...   Dec 7 2024, 09:53 PM
JamesM   Not only are the side seals different but the ch...   Dec 8 2024, 08:23 PM
fixer34   FWIW, I did the exact opposite to my '70 over ...   Dec 7 2024, 06:26 PM
JamesM   While there are changes to the roof itself and the...   Dec 7 2024, 07:34 PM
cgnj   @DC_neun_vierzehn I have a 1970 top, a 73 914 wit...   Dec 7 2024, 10:12 PM
DC_neun_vierzehn   @[url=http://www.914world.com/bbs2/index.php?show...   Dec 8 2024, 09:34 AM
DC_neun_vierzehn   I just laid down both naked tops (no hardware, no ...   Dec 10 2024, 03:08 PM
930cabman   I just laid down both naked tops (no hardware, no...   Dec 10 2024, 05:06 PM
SirAndy   I just laid down both naked tops (no hardware, no...   Dec 10 2024, 05:19 PM
JamesM   :idea: On mine (late top, early doors), i had ...   Dec 11 2024, 01:11 AM
Literati914   Not only are the side seals different but the c...   Dec 12 2024, 09:39 AM
- Lo-Fi Version Time is now: 14th October 2026 - 01:43 PM
