| spencercanon |
Dec 16 2024, 12:27 PM
Newbie ![]() Group: Members Posts: 8 Joined: 25-November 24 From: Bishop, California Member No.: 28,482 Region Association: Central California |
Hi all this is my first post here! I recently picked up a ’75 1.8 that was last registered in 2001! Pretty good barn find, in my opinion. It was up in the high desert of California, so no rust, great mechanicals, all the electrics work. Just flaking paint, decayed interior …and an engine that probably hasn’t run since the Clinton Administration.
The TLDR is the car has started and run for 10 seconds but now won’t start at all. A quick timeline of what I’ve done/tested: - Dropped the engine, adjusted valves (encountered something strange that I’ll ask about later) - Old starter could barely turn the engine over. Replaced it with a hi-torque. - good compression - Replaced the old broken bellows thermostat - New fuel lines, vac lines, spark plugs and wires - deleted EGR system - Fuel pump was getting power but dead - replaced it. - Coil’s good. Cap and rotor look good. Points gapped. - The L-Jet AFM had been opened and the adjustment wheel inside was so loose that it the flap wasn’t closing fully so the pump was running continuously. I rotated the wheel until there was enough tension to turn off the fuel pump. (I would have normally never touched the AFM!) Put the engine back in and the car started on the key immediately, ran for 10 seconds and died. I tried again, it started and ran for 5 seconds, then popped loudly back up the intake with enough force to blow the intake boot off the AFM. Since then, it hasn’t started. Couple notes: - after the pop, I felt like the intake pipe connector hoses were probably leaking, so I put hose clamps on them. With those clamped down and fresh vac lines everywhere, I’m pretty sure there aren’t any more leaks. - oil filler breather nipple broke so I’ve taped it off until I can get a new one. But I’m not sure how this affects the vacuum… should it be left open for now? - I don’t know the fuel pressure but it does have a new pump and lines so I’d be surprised if pressure is the problem. - tested injector ballasts and got correct ohm readings - It did start and run on its own spark and fuel, so I assume ECU and injectors are OK. - the AFM is obviously an issue … probably considerably off. But again, the car did at least start a few times. So now what? - I’d like to check/test anything I can before I start buying replacement components. - Are there baseline settings for idle speed screw, and at least a “best guess” AFM setup? - Should I just buy another AFM now, knowing this one may never be right again? - could the intake backfire have damaged something? Thanks in advance for your thoughts! Attached image(s)
| VaccaRabite |
Dec 16 2024, 02:30 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
So, yeah. Everything Superhawk said - read it 2x.
You did not mention timing. Timing is a prime suspect for backfires. Over advanced can be an issue. Fueling - I'd guess you are too lean by a good bit. Lean tends to burp through the intake, rich through the exhaust. Given that you moved the AFR to the point that the fuel pump stopped - replace it. I fully agree that you need to understand what is happening with your valves. I'm guessing they are frozen with age, but I'd redo the valve adjustment. Read the below link. I'd say that threat gets to the point of beating a dead horse, but it is THE thread. http://www.914world.com/bbs2/index.php?showtopic=28758 IMO - this is the definitive way to do valves. Once valves are re-adjusted... 1) confirm base timeing 2) confirm compression test 3) leakdown test - this will tell you if you have a valve seat failing. Zach |
spencercanon First start after 25 years - problems Dec 16 2024, 12:27 PM
930cabman :wttc:
Generally a 25 years nap is not a good th... Dec 16 2024, 01:04 PM
Superhawk996
So now what?
- I’d like to check/test anything ... Dec 16 2024, 01:14 PM
porschetub
Hi all this is my first post here! I recently... Dec 16 2024, 01:17 PM
Superhawk996 I’ll add one more thing (well maybe two or thre... Dec 16 2024, 01:26 PM
spencercanon The valve adjustment oddity was that the rocker ar... Dec 16 2024, 01:39 PM
Superhawk996
The valve adjustment oddity was that the rocker a... Dec 16 2024, 01:45 PM
fiacra EDIT: I was writing this while you posted about t... Dec 16 2024, 01:44 PM
technicalninja I'd fire the critter on B12 carb spray next.
I... Dec 16 2024, 01:50 PM
Cairo94507 :wttc: What an excellent first post and introducti... Dec 16 2024, 02:01 PM
technicalninja
The valve adjustment oddity was that the rocker ... Dec 16 2024, 02:02 PM
technicalninja Valve springs that have sat in a single position f... Dec 16 2024, 02:06 PM
930cabman What a great forum, 11 posts and the new guy has o... Dec 16 2024, 02:06 PM
spencercanon I'm digesting all the excellent advice from al... Dec 16 2024, 02:43 PM
SirAndy "Will it start", "Does it turn over... Dec 16 2024, 02:52 PM
worn
"Will it start", "Does it turn ove... Dec 16 2024, 10:39 PM
worn
"Will it start", "Does it turn ove... Dec 20 2024, 08:42 PM
spencercanon SirAndy's post is rhetorical I guess. But the ... Dec 16 2024, 03:57 PM
spencercanon I dropped the engine back out and pulled the intak... Dec 16 2024, 04:29 PM
technicalninja
SirAndy's post is rhetorical I guess. But the... Dec 16 2024, 05:24 PM
Jack Standz Hey, good luck with the fix.
Yeah, the valves are... Dec 16 2024, 05:53 PM
technicalninja :agree: :agree:
You'll use that borescope t... Dec 16 2024, 06:21 PM
spencercanon Thanks again everyone for the responses. All my wr... Dec 16 2024, 06:45 PM
Artfrombama
3) I physically verified #1 TDC and the distribu... Dec 17 2024, 10:12 PM
technicalninja If you pull the pushrod tubes (you need to change ... Dec 16 2024, 06:55 PM
spencercanon It would be just like me to get the cyl numbering ... Dec 16 2024, 07:30 PM
ctc911ctc Please say it was sarcasm, Hydraulic ? <_< ... Dec 17 2024, 03:52 PM
Superhawk996
If you pull the pushrod tubes (you need to change... Dec 17 2024, 09:34 AM
930cabman
If you pull the pushrod tubes (you need to chang... Dec 17 2024, 11:03 AM
technicalninja The L-jet FI system has a "cold start" i... Dec 16 2024, 07:18 PM
technicalninja You're good. Make sure the valves on cylinder#... Dec 16 2024, 08:03 PM
spencercanon
I'd REALLY want to find out anything I could... Dec 16 2024, 09:06 PM
Jack Standz
I'd REALLY want to find out anything I coul... Dec 17 2024, 05:30 AM
technicalninja I am not an engineer.
I am a Technician!
The ... Dec 17 2024, 11:21 AM
technicalninja If we're all wrong and your engine is fine, yo... Dec 17 2024, 01:49 PM
Root_Werks :popcorn:
From some of the posts, almost sounds ... Dec 17 2024, 03:11 PM
Jack Standz Good point by TechnicalNinja about the distributor... Dec 17 2024, 04:16 PM
emerygt350 But it ran.... Dec 17 2024, 05:52 PM
Superhawk996
But it ran....
Until it didn’t :evilgrin:
Thi... Dec 17 2024, 07:57 PM
technicalninja
3) I physically verified #1 TDC and the distrib... Dec 17 2024, 11:03 PM
Artfrombama
[quote name='Artfrombama' post='3181951' date='De... Dec 18 2024, 12:26 AM
VaccaRabite
[quote name='Artfrombama' post='3181951' date='D... Dec 18 2024, 04:24 AM
ctc911ctc
[quote name='Artfrombama' post='3181959' date='De... Dec 20 2024, 11:59 AM
Geezer914 I would consider replacing the valve springs and m... Dec 18 2024, 08:57 AM
technicalninja
[quote name='Artfrombama' post='3181951' date='D... Dec 18 2024, 09:48 AM
VaccaRabite I meant to add this last night...
There was a tim... Dec 18 2024, 12:57 PM
930cabman
There was a ti... Dec 18 2024, 01:50 PM
technicalninja TLDR: Sodium filled valves are not inherently bad ... Dec 18 2024, 10:04 PM
barefoot
TLDR: Sodium filled valves are not inherently bad... Dec 19 2024, 09:35 AM
technicalninja Barefoot, I'm in agreement! :agree:
Than... Dec 19 2024, 10:49 AM
VaccaRabite I was not aware you could even GET sodium filled v... Dec 20 2024, 08:19 AM
flipb Inconel was created for spaceflight. I've got ... Dec 20 2024, 10:42 AM
technicalninja
Inconel was created for spaceflight. I've got... Dec 20 2024, 01:14 PM
Spoke About starting an engine after a long sleep, I bou... Dec 20 2024, 09:02 PM
technicalninja
"Will it start", "Does it turn ov... Dec 20 2024, 09:48 PM
Tonyooc Nice Lotus, haven't seen one of those in a whi... Oct 31 2025, 05:02 PM
rgalla9146 I admit I haven't read every word but must say... Oct 31 2025, 09:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:49 PM |
