> 3.2 Carerra Motor SMOKING
CaltranCraig
post Mar 2 2005, 02:39 PM
I have a 3.2 1985 carerra motor in my 914...Great power, great fun... The problem. It smokes while idle...but mainly after it has warmed up. When under load, and when I lay into it, no smoking?
Could this be a vacume issue, oil distribution issue? easy fix you think? Or do I face facts.....need valve guides? valve seals? or engine overhaul (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Could anyone suggest?
Craig
sixnotfour
post Dec 24 2024, 05:36 PM
Simple..owner not aware of a rod knock and needed a top end..I do rod bearings ,on every top end on 3.2..and rod bolts
CaltranCraig   3.2 Carerra Motor SMOKING   Mar 2 2005, 02:39 PM
Series9   Like this: http://www.914worl...   Mar 2 2005, 02:53 PM
Joe Sharp   Welcome to the insanity Craig. Wish I had an answe...   Mar 2 2005, 02:55 PM
rick 918-S   Welcome, I was going to post some incorrect info a...   Mar 2 2005, 02:56 PM
Travis Neff   smoke on deceleration usually is with the valve gu...   Mar 2 2005, 02:59 PM
MattR   I see you're in newport beach. Theres going t...   Mar 2 2005, 03:01 PM
Type 4   Did you change the oil then it started smoking?   Mar 2 2005, 04:26 PM
!   The common knock on 3.2s is valve guides.... Depe...   Mar 2 2005, 04:59 PM
Root_Werks   The common knock on 3.2s is valve guides.... Dep...   Oct 25 2024, 11:24 AM
BigD9146gt   Whats up Craig! If I find a wreck some what so...   Mar 3 2005, 07:47 PM
scotty b   Hey thanks a lot BigD http://w...   Mar 3 2005, 07:53 PM
jim_hoyland   Nice car Craig! Got to see it last Sunday in H...   Mar 5 2005, 06:11 PM
jim_hoyland   Ok; did you get it fixed ? :D @CaltranCraig   Oct 21 2024, 06:27 PM
campbellcj   Ok; did you get it fixed ? :D [b]@[url=http://w...   Oct 21 2024, 06:33 PM
jim_hoyland   It a record; but, I recently heard from Craig and ...   Oct 21 2024, 07:43 PM
CaltranCraig   It’s got to be the record. Dan did a major engi...   Nov 26 2024, 11:58 AM
Justinp71   It’s got to be the record. Dan did a major eng...   Nov 26 2024, 05:44 PM
CaltranCraig   [quote name='CaltranCraig' post='3179...   Dec 24 2024, 04:10 PM
jim_hoyland   :Qarl: good to hear Craig   Nov 26 2024, 12:22 PM
sixnotfour   Simple..owner not aware of a rod knock and needed ...   Dec 24 2024, 05:36 PM
r_towle   So technically a full rebuild   Dec 24 2024, 08:45 PM
sixnotfour   So technically a full rebuild Today yes....BITD ...   Dec 25 2024, 12:22 AM
porschetub   So technically a full rebuild Today yes....BITD...   Dec 25 2024, 01:00 AM
mepstein   3.2’s have undersized rod bolts. If you use stoc...   Dec 25 2024, 08:26 AM
sixnotfour   3.2’s have undersized rod bolts. If you use sto...   Dec 26 2024, 08:45 AM
porschetub   3.2’s have undersized rod bolts. If you use sto...   Dec 28 2024, 10:25 PM
r_towle   I will simply put an option out there. If it’s n...   Dec 26 2024, 12:46 PM
technicalninja   I will simply put an option out there. If it’s ...   Dec 26 2024, 01:11 PM
- Lo-Fi Version Time is now: 1st April 2026 - 08:41 PM
