| CaltranCraig |
Mar 2 2005, 02:39 PM
Newbie ![]() Group: Members Posts: 10 Joined: 2-March 05 From: Folsom, CA Member No.: 3,698 Region Association: None |
I have a 3.2 1985 carerra motor in my 914...Great power, great fun... The problem. It smokes while idle...but mainly after it has warmed up. When under load, and when I lay into it, no smoking?
Could this be a vacume issue, oil distribution issue? easy fix you think? Or do I face facts.....need valve guides? valve seals? or engine overhaul (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Could anyone suggest? Craig |
| r_towle |
Dec 24 2024, 08:45 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
So technically a full rebuild
| sixnotfour |
Dec 25 2024, 12:22 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,183 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| porschetub |
Dec 25 2024, 01:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So technically a full rebuild Today yes....BITD No,, top end time,, and while youre there..rod bearings.. (IMG:style_emoticons/default/agree.gif) ,the job is so much bigger than just doing guides ,one of those "while you are in there " jobs which IMO is critical with a 911 motor and that can't be ignored. Strange that ran one rod bearing ? the 3.2 is regarded as being strong in that area , old news but just asking ,cheers. |
CaltranCraig 3.2 Carerra Motor SMOKING Mar 2 2005, 02:39 PM
Series9 Like this: http://www.914worl... Mar 2 2005, 02:53 PM
Joe Sharp Welcome to the insanity Craig. Wish I had an answe... Mar 2 2005, 02:55 PM
rick 918-S Welcome, I was going to post some incorrect info a... Mar 2 2005, 02:56 PM
Travis Neff smoke on deceleration usually is with the valve gu... Mar 2 2005, 02:59 PM
MattR I see you're in newport beach. Theres going t... Mar 2 2005, 03:01 PM
Type 4 Did you change the oil then it started smoking? Mar 2 2005, 04:26 PM
! The common knock on 3.2s is valve guides....
Depe... Mar 2 2005, 04:59 PM
Root_Werks
Dep... Oct 25 2024, 11:24 AM
BigD9146gt Whats up Craig! If I find a wreck some what so... Mar 3 2005, 07:47 PM
scotty b Hey thanks a lot BigD http://w... Mar 3 2005, 07:53 PM
jim_hoyland Nice car Craig! Got to see it last Sunday in H... Mar 5 2005, 06:11 PM
jim_hoyland Ok; did you get it fixed ? :D
@CaltranCraig Oct 21 2024, 06:27 PM
campbellcj
[b]@[url=http://w... Oct 21 2024, 06:33 PM
jim_hoyland It a record; but, I recently heard from Craig and ... Oct 21 2024, 07:43 PM
CaltranCraig It’s got to be the record. Dan did a major engi... Nov 26 2024, 11:58 AM
Justinp71
It’s got to be the record. Dan did a major eng... Nov 26 2024, 05:44 PM
CaltranCraig
[quote name='CaltranCraig' post='3179... Dec 24 2024, 04:10 PM
jim_hoyland :Qarl: good to hear Craig Nov 26 2024, 12:22 PM
sixnotfour Simple..owner not aware of a rod knock and needed ... Dec 24 2024, 05:36 PM
mepstein 3.2’s have undersized rod bolts. If you use stoc... Dec 25 2024, 08:26 AM
sixnotfour
3.2’s have undersized rod bolts. If you use sto... Dec 26 2024, 08:45 AM
porschetub
3.2’s have undersized rod bolts. If you use sto... Dec 28 2024, 10:25 PM
r_towle I will simply put an option out there.
If it’s n... Dec 26 2024, 12:46 PM
technicalninja
If it’s ... Dec 26 2024, 01:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 08:34 PM |
