> No Brakes - how hard to replace master cylinder plus lines?, looking for some guidance before I dig into my manuals...
potomacmidget
post Dec 26 2024, 11:41 AM
I gotta have more cowbell....
Merry Christmas everyone,
So, my brakes have been really soft, and I figured they were due a bleeding so I bought a pressure bleeder (watched Ian Karr video) and put my car on jackstands and removed all the wheels. Topped off the reservoir with fluid, then when I inspected the master cylinder and observed it was visibly "wet" with what I could only suspect was fresh fluid. First thought was "ok, not good, that must be my pedal problem" then I reached in there with an open end wrench to see if I could snug the connection, and the tubing (vertical) was not even connected to the MC, it just swung away when I touched it, then all the fluid poured out. I guess the threaded part of the tubing rotted away in the MC?
Regardless - looks like I need a new MC, and will have to inspect/replace sketchy lines, etc., and all that comes with that project.
Prior to diving into my collection of service manuals, any guidance on the challenges of this job? Do's and Dont's? It looks a bit nightmarish to access the MC, and since my simple job turned a lot harder, I will wait until my garage is warmer than 30F. All advice appreciated...
thanks,
Reg
Craigers17
post Dec 26 2024, 04:26 PM
If you’re going to replace the MC, just be aware that once you start the process, you will likely open up a can of worms where, “while you’re in there”, you’ll want to assess the condition of your pedal cluster and possibly want to refurbish. Which if/when you remove the cluster, you will be tempted to replace the accelerator and clutch cables…so on and so forth.
Also, while maybe not necessary, the MC and reservoir lines are more easily accessed by at least partially lifting the gas tank. While you have that raised, you’ll likely be tempted to replace the under-tank fuel lines, which will in turn tempt you to replace the fuel sock filter in the tank, which will require you to replace the gaskets that go between the tank and the fuel line fittings. Just saying…
potomacmidget   No Brakes - how hard to replace master cylinder plus lines?   Dec 26 2024, 11:41 AM
mepstein   It’s a pita but easily done by someone without m...   Dec 26 2024, 01:23 PM
r_towle   If you have decided to replace all the hard lines,...   Dec 26 2024, 02:07 PM
emerygt350   If you are going in, you might as well replace MC ...   Dec 26 2024, 03:33 PM
mepstein   I had an MC give out on me just as I pulled into m...   Dec 26 2024, 03:59 PM
Craigers17   If you’re going to replace the MC, just be aware...   Dec 26 2024, 04:26 PM
DC_neun_vierzehn   If you’re going to replace the MC, just be awar...   Dec 27 2024, 11:48 AM
technicalninja   It sounds like the feed tubes came out of the mast...   Dec 26 2024, 06:50 PM
potomacmidget   Dear All - I really appreciate all of the respon...   Dec 27 2024, 11:14 AM
rhodyguy   While shopping at PMB, get 4 speed bleeders. Sourc...   Dec 27 2024, 12:27 PM
fiacra   Since you plan to do all of the lines, including t...   Dec 27 2024, 06:19 PM
technicalninja   :agree: Well done Fiacra. That tapping trick work...   Dec 27 2024, 07:39 PM
VaccaRabite   I just did this on my car. After 15ish years of s...   Dec 29 2024, 10:01 AM
potomacmidget   Hi Zach, technicalninja, Fiacra, Rhodyguy, ,DC neu...   Jan 2 2025, 08:18 PM
technicalninja   Midget to 914... Awesome trade! :first: You...   Jan 2 2025, 09:33 PM
Jamie   Midget to 914... Awesome trade! :first: Yo...   Jan 4 2025, 09:36 AM
thomasotten   If you do replace with stainless steel, be sure to...   Jan 4 2025, 04:54 AM
bkrantz   If you do replace with stainless steel, be sure t...   Jan 4 2025, 09:52 PM
Craigers17   Here's a link to my virgin experience in this ...   Jan 4 2025, 06:02 AM
gereed75   Great advice for the OP. I have used several prem...   Jan 4 2025, 10:00 AM
Superhawk996   I am about to install a -3AN kit on my driver qu...   Jan 4 2025, 11:07 AM
mepstein   I’m no brake expert (for sure) but we like to st...   Jan 4 2025, 11:09 AM
technicalninja   Great advice for the OP. I have used several pre...   Jan 4 2025, 11:52 AM
gereed75   Hawk, I get your perspective but I don’t see an...   Jan 4 2025, 12:44 PM
Superhawk996   Hawk, I get your perspective but I don’t see a...   Jan 4 2025, 02:40 PM
gereed75   These lines are kitted with factory made fittins ...   Jan 4 2025, 10:17 PM
Superhawk996   These lines are kitted with factory made fittings...   Jan 5 2025, 12:20 AM
iankarr   I made a few videos on installing a new MC and ble...   Jan 4 2025, 05:56 PM
technicalninja   I just did this on my car. After 15ish years of ...   Jan 4 2025, 10:06 PM
gereed75   Thanks Hawk. All important considerations.and I ap...   Jan 5 2025, 09:19 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:47 AM
