| brooks944 |
Dec 26 2024, 02:36 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Hi, I have a 1.8 ( now 1911) with 40 Webers and Web cam. It has run rich and my local shop has changed jets and it was running strong. I am now having starting problems and it seems to smell like it’s rich again. Last time I drove it it backfired a couple of times under load and it sounded like the backfire was from the carbs(?). My main question is on the fuel pump, which is a faucet type from the local auto parts store. Should the pump run continuously or shut off when a certain pressure is reached? Mine runs all the time when the key is on. I don’t believe there is a fuel pressure regulator on now.
Thanks for your help on my issues, Rick |
| brooks944 |
Dec 27 2024, 11:01 AM
Thanks everyone for replies. On the CB Performance pump in the attachment of one reply, it says it runs at 3.5 psi, which another commenter said was to high (wrote it needs to be lass than 3). Is the extra 0.5 psi a concern?
Thanks! |
brooks944 Fuel pump with carbs Dec 26 2024, 02:36 PM
moto914 My 914 that has carbs , has the same setup but wit... Dec 26 2024, 02:56 PM
930cabman Fuel pressure must be less than 3 psi, also fuel l... Dec 26 2024, 03:00 PM
GregAmy Pump runs all the time.
You want a fuel pressure ... Dec 26 2024, 03:45 PM
brooks944 Thanks for the replies. What fuel pressure regulat... Dec 26 2024, 03:54 PM
technicalninja Every square Faucet style I've installed REQUI... Dec 26 2024, 04:44 PM
Osnabruck914 Get a low pressure rotary type pump. You will be ... Dec 26 2024, 07:19 PM
the fuel return line will help quiet it down some... Dec 26 2024, 08:53 PM
Front yard mechanic the fuel return line will help quiet it down some.... Dec 26 2024, 08:24 PM
technicalninja I have another use for the Facet...
the ONLY one ... Dec 26 2024, 09:01 PM
porschetub
Thanks everyone for replies. On the CB Performanc... Dec 27 2024, 12:35 PM
930cabman
Thanks everyone for replies. On the CB Performan... Dec 27 2024, 01:42 PM
rhodyguy Facet pumps are dandy for emptying fuel tanks and ... Dec 27 2024, 12:23 PM
rfinegan Yes, the fuel pump will run off the ignition switc... Dec 27 2024, 02:33 PM
brooks944 Thanks all. Porschetub, I ordered the one you reco... Dec 27 2024, 03:44 PM
mlindner
Thanks all. Porschetub, I ordered the one you rec... Dec 28 2024, 01:09 PM
VaccaRabite
Most by the steering rack or under the tank. I pu... Jan 6 2025, 07:51 AM
porschetub
Thanks all. Porschetub, I ordered the one you rec... Dec 28 2024, 02:24 PM
mlindner
Thanks all. Porschetub, I ordered the one you re... Jan 3 2025, 02:11 PM
brooks944 Thanks all for responses. Does anyone have pictur... Jan 3 2025, 01:17 PM
porschetub
Thanks all for responses. Does anyone have pictu... Jan 3 2025, 05:10 PM
brooks944 Also where should the gauge be located? The FPR ha... Jan 3 2025, 01:47 PM
mlindner
Also where should the gauge be located? The FPR h... Jan 3 2025, 02:14 PM
brooks944 Thanks, does the gauge placement matter after the ... Jan 3 2025, 03:46 PM
brooks944 Got the recommended regulator and gauge installed,... Feb 4 2025, 01:26 PM
technicalninja pull main and idle jets, clean the piss out of the... Feb 4 2025, 03:01 PM
brant Please install any pressure guage onto a chassis p... Feb 4 2025, 03:41 PM
Jack Standz
Got the recommended regulator and gauge installed... Feb 4 2025, 06:09 PM
Jack Standz Mixture: An Air Fuel Ratio meter/gauge is a very g... Feb 4 2025, 06:33 PM
rhodyguy For my carb pump, I removed the pump wire plug (do... Feb 4 2025, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 08:23 PM |
