| brooks944 |
Dec 26 2024, 02:36 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Hi, I have a 1.8 ( now 1911) with 40 Webers and Web cam. It has run rich and my local shop has changed jets and it was running strong. I am now having starting problems and it seems to smell like it’s rich again. Last time I drove it it backfired a couple of times under load and it sounded like the backfire was from the carbs(?). My main question is on the fuel pump, which is a faucet type from the local auto parts store. Should the pump run continuously or shut off when a certain pressure is reached? Mine runs all the time when the key is on. I don’t believe there is a fuel pressure regulator on now.
Thanks for your help on my issues, Rick |
| brooks944 |
Dec 27 2024, 03:44 PM
Thanks all. Porschetub, I ordered the one you recommended. Do you have a picture where you mounted yours?
| mlindner |
Dec 28 2024, 01:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
brooks944 Fuel pump with carbs Dec 26 2024, 02:36 PM
moto914 My 914 that has carbs , has the same setup but wit... Dec 26 2024, 02:56 PM
930cabman Fuel pressure must be less than 3 psi, also fuel l... Dec 26 2024, 03:00 PM
GregAmy Pump runs all the time.
You want a fuel pressure ... Dec 26 2024, 03:45 PM
brooks944 Thanks for the replies. What fuel pressure regulat... Dec 26 2024, 03:54 PM
technicalninja Every square Faucet style I've installed REQUI... Dec 26 2024, 04:44 PM
Osnabruck914 Get a low pressure rotary type pump. You will be ... Dec 26 2024, 07:19 PM
the fuel return line will help quiet it down some... Dec 26 2024, 08:53 PM
Front yard mechanic the fuel return line will help quiet it down some.... Dec 26 2024, 08:24 PM
technicalninja I have another use for the Facet...
the ONLY one ... Dec 26 2024, 09:01 PM
brooks944 Thanks everyone for replies. On the CB Performance... Dec 27 2024, 11:01 AM
porschetub
Thanks everyone for replies. On the CB Performanc... Dec 27 2024, 12:35 PM
930cabman
Thanks everyone for replies. On the CB Performan... Dec 27 2024, 01:42 PM
rhodyguy Facet pumps are dandy for emptying fuel tanks and ... Dec 27 2024, 12:23 PM
rfinegan Yes, the fuel pump will run off the ignition switc... Dec 27 2024, 02:33 PM
VaccaRabite
Most by the steering rack or under the tank. I pu... Jan 6 2025, 07:51 AM
porschetub
Thanks all. Porschetub, I ordered the one you rec... Dec 28 2024, 02:24 PM
mlindner
Thanks all. Porschetub, I ordered the one you re... Jan 3 2025, 02:11 PM
brooks944 Thanks all for responses. Does anyone have pictur... Jan 3 2025, 01:17 PM
porschetub
Thanks all for responses. Does anyone have pictu... Jan 3 2025, 05:10 PM
brooks944 Also where should the gauge be located? The FPR ha... Jan 3 2025, 01:47 PM
mlindner
Also where should the gauge be located? The FPR h... Jan 3 2025, 02:14 PM
brooks944 Thanks, does the gauge placement matter after the ... Jan 3 2025, 03:46 PM
brooks944 Got the recommended regulator and gauge installed,... Feb 4 2025, 01:26 PM
technicalninja pull main and idle jets, clean the piss out of the... Feb 4 2025, 03:01 PM
brant Please install any pressure guage onto a chassis p... Feb 4 2025, 03:41 PM
Jack Standz
Got the recommended regulator and gauge installed... Feb 4 2025, 06:09 PM
Jack Standz Mixture: An Air Fuel Ratio meter/gauge is a very g... Feb 4 2025, 06:33 PM
rhodyguy For my carb pump, I removed the pump wire plug (do... Feb 4 2025, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 08:17 PM |
