> 3.2 Carerra Motor SMOKING
CaltranCraig
post Mar 2 2005, 02:39 PM
I have a 3.2 1985 carerra motor in my 914...Great power, great fun... The problem. It smokes while idle...but mainly after it has warmed up. When under load, and when I lay into it, no smoking?
Could this be a vacume issue, oil distribution issue? easy fix you think? Or do I face facts.....need valve guides? valve seals? or engine overhaul (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Could anyone suggest?
Craig
post Dec 25 2024, 08:26 AM
914-6 GT in waiting
3.2’s have undersized rod bolts. If you use stock rods, you always upgrade the bolts to ARP.
We rarely do just a top end. We can’t “warranty” the rebuild without splitting the case. Who knows what else is wrong. Intermediate shaft bearing, main bearings, issues with the fuel pump, etc. Every time we open one up, there’s always something that makes us say that we are glad we split the case.
It’s not cheap but it’s really expensive to have to go back in and do it twice.
porschetub
post Dec 28 2024, 10:25 PM
QUOTE(mepstein @ Dec 26 2024, 03:26 AM) *
I certainly understand the need for the engine to be suitable for resale , thanks for the info I had no idea of this issue ,cheers.
CaltranCraig   3.2 Carerra Motor SMOKING   Mar 2 2005, 02:39 PM
Series9   Like this: http://www.914worl...   Mar 2 2005, 02:53 PM
Joe Sharp   Welcome to the insanity Craig. Wish I had an answe...   Mar 2 2005, 02:55 PM
rick 918-S   Welcome, I was going to post some incorrect info a...   Mar 2 2005, 02:56 PM
Travis Neff   smoke on deceleration usually is with the valve gu...   Mar 2 2005, 02:59 PM
MattR   I see you're in newport beach. Theres going t...   Mar 2 2005, 03:01 PM
Type 4   Did you change the oil then it started smoking?   Mar 2 2005, 04:26 PM
!   The common knock on 3.2s is valve guides.... Depe...   Mar 2 2005, 04:59 PM
Root_Werks   The common knock on 3.2s is valve guides.... Dep...   Oct 25 2024, 11:24 AM
BigD9146gt   Whats up Craig! If I find a wreck some what so...   Mar 3 2005, 07:47 PM
scotty b   Hey thanks a lot BigD http://w...   Mar 3 2005, 07:53 PM
jim_hoyland   Nice car Craig! Got to see it last Sunday in H...   Mar 5 2005, 06:11 PM
jim_hoyland   Ok; did you get it fixed ? :D @CaltranCraig   Oct 21 2024, 06:27 PM
campbellcj   Ok; did you get it fixed ? :D [b]@[url=http://w...   Oct 21 2024, 06:33 PM
jim_hoyland   It a record; but, I recently heard from Craig and ...   Oct 21 2024, 07:43 PM
CaltranCraig   It’s got to be the record. Dan did a major engi...   Nov 26 2024, 11:58 AM
Justinp71   It’s got to be the record. Dan did a major eng...   Nov 26 2024, 05:44 PM
CaltranCraig   [quote name='CaltranCraig' post='3179...   Dec 24 2024, 04:10 PM
jim_hoyland   :Qarl: good to hear Craig   Nov 26 2024, 12:22 PM
sixnotfour   Simple..owner not aware of a rod knock and needed ...   Dec 24 2024, 05:36 PM
r_towle   So technically a full rebuild   Dec 24 2024, 08:45 PM
sixnotfour   So technically a full rebuild Today yes....BITD ...   Dec 25 2024, 12:22 AM
porschetub   So technically a full rebuild Today yes....BITD...   Dec 25 2024, 01:00 AM
mepstein   3.2’s have undersized rod bolts. If you use stoc...   Dec 25 2024, 08:26 AM
sixnotfour   3.2’s have undersized rod bolts. If you use sto...   Dec 26 2024, 08:45 AM
porschetub   3.2’s have undersized rod bolts. If you use sto...   Dec 28 2024, 10:25 PM
r_towle   I will simply put an option out there. If it’s n...   Dec 26 2024, 12:46 PM
technicalninja   I will simply put an option out there. If it’s ...   Dec 26 2024, 01:11 PM
- Lo-Fi Version Time is now: 1st April 2026 - 08:40 PM
