> Another Rennshift Issue - 1974 Side-shift
LefthandRev
post Jan 1 2025, 05:20 PM
I think I've read every Rennshift post on the forum trying to figure out WTAF is going on with my car and this installation.
Here's the quick and dirty version:
  • Put the stock into 2nd gear
  • Removed the stock shifter
  • Put coupler onto shaft, flat face forward
  • Seated the new shifter.
  • It won't line up with the mounting holes
I got under the car, tried to adjust the shifter rod where it links up behind the firewall, but it's just too short. I can't put the gear into 2nd no matter what I try.
It has not been modified.
I was thinking about either adding length to the front of the rod in the cabin, or removing it, drilling a new hole for the pin, and extending it forward by the inch or so that is needed to make this work... IF there's enough length to do that.
I'm super annoyed by this.
rick 918-S
post Jan 2 2025, 07:24 AM
Hey nice rack! -Celette
QUOTE(LefthandRev @ Jan 1 2025, 05:20 PM) *
This seems to indicate you have a tail shift linkage.
"I got under the car, tried to adjust the shifter rod where it links up behind the firewall, but it's just too short. I can't put the gear into 2nd no matter what I try."
LefthandRev   Another Rennshift Issue - 1974 Side-shift   Jan 1 2025, 05:20 PM
sixnotfour   is that a 914 side model JWSTRSSDSTSN   Jan 1 2025, 08:06 PM
mepstein   is that a 914 side model JWSTRSSDSTSN Yea, Wha...   Jan 1 2025, 09:08 PM
LefthandRev   is that a 914 side model JWSTRSSDSTSN Yea, Wh...   Jan 1 2025, 10:22 PM
sixnotfour   [quote name='mepstein' post='3184441' date='Jan 1...   Jan 1 2025, 10:35 PM
LefthandRev   [quote name='mepstein' post='3184441' date='Jan ...   Jan 1 2025, 10:37 PM
sixnotfour   :beer2: Gearbox/Car Type: 914 Side-Shift (Clevis ...   Jan 1 2025, 10:48 PM
sixnotfour   https://cdn.shopify.com/s/files/1/0521/8792...df?v...   Jan 1 2025, 11:07 PM
VaccaRabite   I'm really confused here. Is your car a tailsh...   Jan 2 2025, 06:59 AM
mepstein   I have a feeling it’s just a miscommunication ab...   Jan 2 2025, 07:09 AM
LefthandRev   I have a feeling it’s just a miscommunication a...   Jan 2 2025, 10:13 AM
rick 918-S   I think I've read every Rennshift post on the...   Jan 2 2025, 07:24 AM
mepstein   I would also take some pics of the engine side fir...   Jan 2 2025, 07:31 AM
LefthandRev   I would also take some pics of the engine side fi...   Jan 2 2025, 10:14 AM
sixnotfour   :popcorn:   Jan 2 2025, 04:20 PM
sixnotfour   Make sure they select... Gearbox/Car Type: 914 Sid...   Jan 2 2025, 04:28 PM
LefthandRev   Make sure they select... Gearbox/Car Type: 914 Si...   Jan 3 2025, 11:23 AM
sixnotfour   Great News,, Is it Raining in Seattle?? l Lived...   Jan 3 2025, 07:37 PM
Montreal914   I am sure if you contact James at JWest, he will h...   Jan 5 2025, 09:24 PM
LefthandRev   I am sure if you contact James at JWest, he will ...   Jan 30 2025, 12:29 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:06 AM
