Here's the quick and dirty version:
- Put the stock into 2nd gear
- Removed the stock shifter
- Put coupler onto shaft, flat face forward
- Seated the new shifter.
- It won't line up with the mounting holes
It has not been modified.
I was thinking about either adding length to the front of the rod in the cabin, or removing it, drilling a new hole for the pin, and extending it forward by the inch or so that is needed to make this work... IF there's enough length to do that.
I'm super annoyed by this.
