| potomacmidget |
Dec 26 2024, 11:41 AM
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 170 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States
Merry Christmas everyone,
So, my brakes have been really soft, and I figured they were due a bleeding so I bought a pressure bleeder (watched Ian Karr video) and put my car on jackstands and removed all the wheels. Topped off the reservoir with fluid, then when I inspected the master cylinder and observed it was visibly "wet" with what I could only suspect was fresh fluid. First thought was "ok, not good, that must be my pedal problem" then I reached in there with an open end wrench to see if I could snug the connection, and the tubing (vertical) was not even connected to the MC, it just swung away when I touched it, then all the fluid poured out. I guess the threaded part of the tubing rotted away in the MC? Regardless - looks like I need a new MC, and will have to inspect/replace sketchy lines, etc., and all that comes with that project. Prior to diving into my collection of service manuals, any guidance on the challenges of this job? Do's and Dont's? It looks a bit nightmarish to access the MC, and since my simple job turned a lot harder, I will wait until my garage is warmer than 30F. All advice appreciated... thanks, Reg |
| gereed75 |
Jan 4 2025, 10:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Great advice for the OP. I have used several premade PMB lines and they are great
Ok, so now for the thread drift - what is the consensus of the world on using -3 AN lines and fittings on a car that you are not worried about originality on. Pretty common in the race car world and in many cases much easier and can eliminate the need to remove suspension components to access fittings/hangars. Can often eliminate couplers and other fittings also minimizing leak points I am about to install a -3AN kit on my driver quality E30 M3. |
potomacmidget No Brakes - how hard to replace master cylinder plus lines? Dec 26 2024, 11:41 AM
mepstein It’s a pita but easily done by someone without m... Dec 26 2024, 01:23 PM
r_towle If you have decided to replace all the hard lines,... Dec 26 2024, 02:07 PM
emerygt350 If you are going in, you might as well replace MC ... Dec 26 2024, 03:33 PM
mepstein I had an MC give out on me just as I pulled into m... Dec 26 2024, 03:59 PM
Craigers17 If you’re going to replace the MC, just be aware... Dec 26 2024, 04:26 PM
DC_neun_vierzehn
If you’re going to replace the MC, just be awar... Dec 27 2024, 11:48 AM
technicalninja It sounds like the feed tubes came out of the mast... Dec 26 2024, 06:50 PM
potomacmidget Dear All -
I really appreciate all of the respon... Dec 27 2024, 11:14 AM
rhodyguy While shopping at PMB, get 4 speed bleeders. Sourc... Dec 27 2024, 12:27 PM
fiacra Since you plan to do all of the lines, including t... Dec 27 2024, 06:19 PM
technicalninja :agree: Well done Fiacra.
That tapping trick work... Dec 27 2024, 07:39 PM
VaccaRabite I just did this on my car. After 15ish years of s... Dec 29 2024, 10:01 AM
potomacmidget Hi Zach, technicalninja, Fiacra, Rhodyguy, ,DC neu... Jan 2 2025, 08:18 PM
technicalninja Midget to 914...
Awesome trade! :first:
You... Jan 2 2025, 09:33 PM
Jamie
Midget to 914...
Yo... Jan 4 2025, 09:36 AM
thomasotten If you do replace with stainless steel, be sure to... Jan 4 2025, 04:54 AM
bkrantz
If you do replace with stainless steel, be sure t... Jan 4 2025, 09:52 PM
Craigers17 Here's a link to my virgin experience in this ... Jan 4 2025, 06:02 AM
Superhawk996
I am about to install a -3AN kit on my driver qu... Jan 4 2025, 11:07 AM
mepstein I’m no brake expert (for sure) but we like to st... Jan 4 2025, 11:09 AM
technicalninja
Great advice for the OP. I have used several pre... Jan 4 2025, 11:52 AM
gereed75 Hawk, I get your perspective but I don’t see an... Jan 4 2025, 12:44 PM
Superhawk996
Hawk, I get your perspective but I don’t see a... Jan 4 2025, 02:40 PM
gereed75 These lines are kitted with factory made fittins ... Jan 4 2025, 10:17 PM
Superhawk996
These lines are kitted with factory made fittings... Jan 5 2025, 12:20 AM
iankarr I made a few videos on installing a new MC and ble... Jan 4 2025, 05:56 PM
technicalninja
I just did this on my car. After 15ish years of ... Jan 4 2025, 10:06 PM
gereed75 Thanks Hawk. All important considerations.and I ap... Jan 5 2025, 09:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:25 AM |
