thecleanoutking |
Newbie ![]() Group: Members Posts: 44 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States ![]() |
Smelled gas the other day when I was about go for a little ride..
I found fuel leaking either from the line or at the drivers side I think its a fuel regulator?, silver cylinder attached to bracket with screw on top looks like a fuel filter but I'm assuming its a regulator there is also one on the passenger side near the fuel pump as well.. Its held on by a bracket that looks to be part of the engine tin, I guess I loosen the nut in my pics and slide it out so I can deal with it a little better.. Is this fuel line similar 8mm braided Fuel line like on my VW's was either going to replace the whole run of it or just trim the line and re-attach ..? ![]() ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,491 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
That looks like it is original hose, or original style hose, and very old. The original hose is not ethanol tolerant, so with today's gas you should replace that with new hose that is ethanol rated and also replace the clamps with proper EFI clamps.
An engine fire will ruin your whole day, so make sure to take care of it soon. |
Lo-Fi Version | Time is now: 1st August 2025 - 03:48 PM |
