thecleanoutking |
Newbie ![]() Group: Members Posts: 44 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States ![]() |
Smelled gas the other day when I was about go for a little ride..
I found fuel leaking either from the line or at the drivers side I think its a fuel regulator?, silver cylinder attached to bracket with screw on top looks like a fuel filter but I'm assuming its a regulator there is also one on the passenger side near the fuel pump as well.. Its held on by a bracket that looks to be part of the engine tin, I guess I loosen the nut in my pics and slide it out so I can deal with it a little better.. Is this fuel line similar 8mm braided Fuel line like on my VW's was either going to replace the whole run of it or just trim the line and re-attach ..? ![]() ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
AND DO ALL OF THE RUBBER HOSES!!!!!!!
Up under the tank, all over the engine compartment, look closely at the injector rubber. Trust NOTHING!!!!!! If it's original it's seen BOTH NTBE and ethanol! Both destroy old school fuel hoses in different ways. MTBE hardens and cracks. Ethanol turns it into marshmallow mush. One final piece is the original plastic center tunnel tubes. Replace with stainless or copper/nickel. Tangerine sells nicely done pieces reasonably priced. Some folks say the plastic tubes (which are a shitload better than the rubber) can even still be used. I disagree highly, especially on high pressure fuel systems. |
Lo-Fi Version | Time is now: 1st August 2025 - 03:48 PM |
