> Fuel Leak, kinda dumb questions, Fuel Leaks
thecleanoutking
post Jan 24 2025, 02:17 PM
Smelled gas the other day when I was about go for a little ride..
I found fuel leaking either from the line or at the drivers side I think its a fuel regulator?, silver cylinder attached to bracket with screw on top looks like a fuel filter but I'm assuming its a regulator there is also one on the passenger side near the fuel pump as well..
Its held on by a bracket that looks to be part of the engine tin, I guess I loosen the nut in my pics and slide it out so I can deal with it a little better..
Is this fuel line similar 8mm braided Fuel line like on my VW's was either going to replace the whole run of it or just trim the line and re-attach ..?
NARP74
post Jan 24 2025, 05:54 PM
Belmetric has real metric hose, proper rating, not just stamped metric sizes on standard hose, and all the proper hose clamps you need.
thecleanoutking   Fuel Leak, kinda dumb questions   Jan 24 2025, 02:17 PM
ClayPerrine   That looks like it is original hose, or original s...   Jan 24 2025, 02:42 PM
thecleanoutking   That looks like it is original hose, or original ...   Jan 24 2025, 02:52 PM
fiacra   [quote name='ClayPerrine' post='3188577' date='Ja...   Jan 24 2025, 03:00 PM
VaccaRabite   REPLACE!!! And do not use any of the ...   Jan 24 2025, 03:01 PM
SirAndy   Also, use proper fuel injection hose clamps. :agr...   Jan 24 2025, 03:14 PM
technicalninja   AND DO ALL OF THE RUBBER HOSES!!!...   Jan 24 2025, 03:17 PM
rjames   Check ALL of your fuel lines. Given what you have ...   Jan 24 2025, 03:21 PM
ClayPerrine   Check ALL of your fuel lines. Given what you have...   Jan 24 2025, 03:47 PM
rjames   Check ALL of your fuel lines. Given what you hav...   Jan 24 2025, 05:20 PM
NARP74   Belmetric has real metric hose, proper rating, not...   Jan 24 2025, 05:54 PM
bkrantz   One more voice of encouragement. Replace all the ...   Jan 24 2025, 08:11 PM
thecleanoutking   Thanks, all good advice, the plan was to drive it ...   Jan 25 2025, 12:29 AM
technicalninja   From what I have read those tunnel lines are a bit...   Jan 25 2025, 10:48 AM
rjames   From what I have read those tunnel lines are a bi...   Jan 25 2025, 10:08 PM
technicalninja   I have another suggestion for what you can do wi...   Jan 25 2025, 10:22 PM
rjames   I have another suggestion for what you can do w...   Jan 27 2025, 05:16 PM
- Lo-Fi Version Time is now: 1st August 2025 - 03:50 PM
