| Mr Beckstar |
Jan 25 2025, 05:37 PM
Newbie ![]() Group: Members Posts: 44 Joined: 28-April 18 From: Australia Member No.: 22,082 Region Association: Australia and New Zealand |
Hi all.
I have a 4 cylinder 2 litre and am adding a remote oil filter and oil cooler circuit via a spin on adaptor attached to the stock oil filter console mount. But I noticed the oil filter bypass valve in the stock oil filter mount (circled in photo below) and now I’m concerned that, at high rpm, I’ll be bypassing the remote cooler/filter circuit. Does anyone know the bypass valve relief pressure setting? Knowing that would at least allow me to judge whether it’s an issue. |
| Montreal914 |
Jan 25 2025, 06:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,191 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Good concern and already discussed here in the past. I believe it is very low pressure and yes, you can by-pass your external oil cooler with the spin adaptor. (IMG:style_emoticons/default/dry.gif)
Here is a thread on the subject: http://www.914world.com/bbs2/index.php?showtopic=10227 |
| Mr Beckstar |
Jan 26 2025, 05:16 AM
Good concern and already discussed here in the past. I believe it is very low pressure and yes, you can by-pass your external oil cooler with the spin adaptor. (IMG:style_emoticons/default/dry.gif) Here is a thread on the subject: http://www.914world.com/bbs2/index.php?showtopic=10227 Yes I’ve seen that thanks Montreal914. Does anyone know the bypass valve relief pressure setting? . |
Mr Beckstar Bypass Valve on Stock Oil Filter Console Jan 25 2025, 05:37 PM
Montreal914 Looks like it is a couple of psi.
Read @[url=htt... Jan 26 2025, 09:55 AM
Superhawk996 I hate chiming in on this because I don’t have a... Jan 26 2025, 12:38 PM
technicalninja :agree:
I believe every single ICE engine with b... Jan 26 2025, 01:00 PM
Mr Beckstar Thanks for the great responses everyone :D
If i... Jan 27 2025, 07:11 AM
Superhawk996 Where in the world did you come up with 3 psi?
I ... Jan 27 2025, 07:44 AM
Mr Beckstar
M... Jan 27 2025, 07:17 PM
Superhawk996
I’m also a mechanical engineer and done a fair... Jan 27 2025, 08:15 PM
Mr Beckstar
I’m also a mechanical engineer and done a fai... Jan 28 2025, 01:31 AM
Superhawk996
The spring will dictate the [force], the [area] i... Jan 28 2025, 07:54 AM
Mr Beckstar
The spring will dictate the [force], the [area] ... Jan 29 2025, 04:00 AM
emerygt350 And why on earth would you want to send cold oil t... Jan 27 2025, 06:22 PM
Mr Beckstar
And why on earth would you want to send cold oil ... Jan 27 2025, 07:22 PM
technicalninja
... Jan 27 2025, 08:19 PM
Mr Beckstar
Sadly, the old saying "if you want somethin... Jan 28 2025, 01:35 AM
technicalninja
I’m also a mechanical engineer and done a fai... Jan 27 2025, 08:25 PM
Mr Beckstar
[quote name='Superhawk996' post='3189070' date='J... Jan 28 2025, 01:38 AM
GregAmy Can I insert just a couple basic questions here?
... Jan 28 2025, 08:11 AM
Mr Beckstar
... Jan 29 2025, 04:16 AM
Superhawk996 I don’t want to answer for OP but my understandi... Jan 28 2025, 10:15 AM
GregAmy
I don’t want to answer for OP but my understand... Jan 28 2025, 10:23 AM
Superhawk996
I suggest it's a non-issue. But if you're... Jan 28 2025, 10:27 AM
Mr Beckstar
I don’t want to answer for OP but my understan... Jan 29 2025, 04:26 AM
Mr Beckstar
…I view this discussion as largely theoretica... Mar 11 2025, 04:17 AM
Mr Beckstar I looked at those two links and they’re not rele... Jan 29 2025, 04:24 AM
Mr Beckstar The oil filter bypass valve piqued my interest so ... Feb 21 2025, 03:31 AM
Mr Beckstar The above pressure readings were measured using th... Feb 21 2025, 04:10 AM
Superhawk996 Interesting data points.
Food for thought on the ... Feb 21 2025, 08:40 AM
Mr Beckstar Okay, I just used a brand new gauge with 0-15 PSI ... Mar 11 2025, 03:13 AM
Mr Beckstar Next step is to fit the two pressure tappings into... Mar 11 2025, 03:29 AM
Superhawk996 You’re in uncharted territory as far as I know. ... Mar 11 2025, 07:06 AM
Mr Beckstar
You’re in uncharted territory as far as I know.... Mar 12 2025, 02:29 AM
Superhawk996 Food for thought
If you look at histograms of av... Mar 12 2025, 07:55 AM
Mr Beckstar
Food for thought
If you look at histograms of a... Mar 13 2025, 01:49 AM
Superhawk996
At 68 MPH, the engine’s doing 4,200 rpm. Bei... Mar 13 2025, 06:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 12:55 AM |
