MONACO |
Newbie ![]() Group: Members Posts: 3 Joined: 24-November 24 From: Victor, New York Member No.: 28,477 Region Association: North East States ![]() |
As a new 914 owner I’ll have numerous questions about the mechanical’s of my car. I’m a long time Porsche enthusiast and owner.
I have owned (2)1977 911S’s, a 924 Turbo and “Best Car Ever” a 1996 Carrera 4S. I currently own a 1986 928S, a 2013 Cayenne GTS and a 2017 Mac S. I grew up through my teenage years working on Volkswagens and have a fair amount of knowledge about them and their inner workings. At age 16, I built a Laser 917 kit car on a completely refurbished 1966 VW chassis. I built it from the ground up, so I’m pretty well-versed in Volkswagen technology and engineering design. I have also converted 1979 VW that had an automatic stick shift and converted it to a standard transmission. I also took the engine that I built for my Laser 917 and installed it into a 1974 Super Beetle at one point in time. I do not know the inner workings and engineering of a 914. I am attaching a photo of an area the engine compartment (driver’s side) and I believe that the components I’m looking at mounted in there are part of the fuel injection system that was originally on this car The car is currently carbureted. Am I correct? Are the superfluous and therefore can be removed? Attached thumbnail(s) ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Sort of looks like an aftermarket cruise control...
If so, somewhere on the car you will have a magnetic pick up or some other way to determine speed. Might be an extra coupling in the speedo cable (will have wiring to it). Super common is a mag sensor reading driveshaft speed. In a 914 it will be on one of the half shafts. I would expect inboard towards/on the inner CV joint. My money is on cruise control... What does that cable hook up to? If its cruise it will connect to the throttle. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
agree certainly not something in ANY 914 engine compartment
Sort of looks like an aftermarket cruise control... If so, somewhere on the car you will have a magnetic pick up or some other way to determine speed. Might be an extra coupling in the speedo cable (will have wiring to it). Super common is a mag sensor reading driveshaft speed. In a 914 it will be on one of the half shafts. I would expect inboard towards/on the inner CV joint. My money is on cruise control... What does that cable hook up to? If its cruise it will connect to the throttle. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 1st July 2025 - 11:45 AM |
