> Fan hub removal, How to?
PaIsa
post Jan 30 2025, 07:01 PM
I was planning on replacing the seal on the fan side of the main shaft but I am having some trouble getting the fan hub.
For now, I have applied some penetrant liquid on it and I will let it soak some time, but then, what is the best way to get it off.
Lightly prying it off going around? I guess that a puller would be useful, but I only have a very large puller that does not fit there. Can I apply some heat in trying to get it off?
Any other tricks or advice?
Thanks
Dave_Darling
post Jan 31 2025, 02:21 AM
914 Idiot
Here's the super-specialized tool that works a trick:
A "church key" bottle opener, or another thick, flat piece of metal.
The three fan mounting bolts.
Hold the church key up behind the fan hub. Thread in a fan bolt until it touches the key. Give it 1 complete turn. Loosen it a bit, move the key to behind the next hole in the hub. Thread in another bolt until it touches, then give it 1 turn.
Continue this process, going around to each of those three holes, until the hub pops off. Shouldn't take long.
For the extra-fancy version, you can use three church keys or fender washers. That way you don't have to back off the bolts to move the key.
--DD
- Lo-Fi Version Time is now: 13th March 2026 - 12:04 PM
