| PaIsa |
Jan 30 2025, 07:01 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada
I was planning on replacing the seal on the fan side of the main shaft but I am having some trouble getting the fan hub.
For now, I have applied some penetrant liquid on it and I will let it soak some time, but then, what is the best way to get it off. Lightly prying it off going around? I guess that a puller would be useful, but I only have a very large puller that does not fit there. Can I apply some heat in trying to get it off? Any other tricks or advice? Thanks |
| Jack Standz |
Jan 31 2025, 11:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
A steering wheel puller does work if it's a three prong/hole version. But, it also needs to be the right size. A two hole version won't really cut it.
Or an harmonic balancer puller of the right size. Either way this job can justify getting another new tool. But, if you don't have the right tool, a piece of sheet metal works, even if it pisses off those with all the right tools. |
PaIsa Fan hub removal Jan 30 2025, 07:01 PM
technicalninja Buy a steering wheel puller.
https://www.harborfr... Jan 30 2025, 07:13 PM
930cabman
https://www.harborf... Jan 31 2025, 08:14 AM
Jack Standz Not near the garage/workshop today, so can't t... Jan 30 2025, 08:37 PM
Dave_Darling Here's the super-specialized tool that works a... Jan 31 2025, 02:21 AM
PaIsa Thanks for the replies.
Will probably be the ... Jan 31 2025, 06:14 AM
Superhawk996 I’m going to piss off the guys that use the flat... Jan 31 2025, 08:03 AM
PaIsa Got it off using the small steering wheel pulley t... Feb 1 2025, 04:44 PM
914werke This is the tool
Feb 1 2025, 05:37 PM
technicalninja :agree:
That would work KICK ASS as it allows ev... Feb 1 2025, 08:20 PM
Dave_Darling That is little different from the "church key... Feb 1 2025, 08:53 PM
ClayPerrine This is what I use:
http://www.914world.com/bbs2/u... Feb 2 2025, 08:14 AM
I've got a 40 years old "Matco... Feb 2 2025, 10:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 12:01 PM |
