| RTz |
Feb 8 2025, 02:54 PM
Newbie ![]() Group: Members Posts: 26 Joined: 18-October 24 From: Oregon City Member No.: 28,424 Region Association: None |
I put this together for one of our 914World members. It slides into the ashtray rails, no fasteners or drilling holes required.
STL: https://www.dropbox.com/scl/fi/2wnqiw1y1to6...75hgoj&dl=0 DWG: https://www.dropbox.com/scl/fi/xlfj9la982y7...jl26rm&dl=0 Disclaimer: 1) Designed for 52mm VDO gauges only. The two gauges shown have different depths, though either gauge will work on either side, I have no knowledge if VDO has built gauges with different depths or stud spacing other than these two. The voltmeter is the deeper gauge and has a body depth of 34mm. 2) Pictured on a '72 model. I assume ashtray's & rails are the same for all years but I don't know that with certainty. Do your own diligence. Peace, Ron |
| infraredcalvin |
Feb 13 2025, 10:06 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,781 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
| fixer34 |
Feb 14 2025, 12:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Very cool, I’d buy one too… +1 on the angled gauges… i did a radio plate with angled (pvc) gauges… two different depths cause one of my gauges had a thicker bezel than the vdo gauge… I think the challenge with doing angled gauges would be it is a much tighter space, plus the right side would need to be a smaller depth. Lastly, they would be offset in the opening; the left gauge tight against the left side, the right one more to center with a wide space on the right side. The only 'glitch' I found so far is apparently the early dash ('70) is a little narrower around the opening on the bottom. |
RTz Double VDO Gauge Pod (Ashtray Mounted, 3d Printed) Feb 8 2025, 02:54 PM
slowrodent Yeah....I'd pay for one of these. Very nicely ... Feb 8 2025, 03:24 PM
emerygt350 Let me know if it shrinks. What filament did you ... Feb 8 2025, 04:25 PM
bkrantz Very nice. If you are open to suggestions, the ne... Feb 8 2025, 09:18 PM
fixer34 So I was the member that worked with RTz (Ron) on ... Feb 13 2025, 06:16 PM
fixer34 more pictures
back
side
bottom view Feb 13 2025, 06:19 PM
Montreal914
Nice part. I like the Gaudi inspired support... Feb 13 2025, 09:34 PM
RTz "New & Improved" version and for sal... Mar 22 2025, 06:05 AM
SKL1 PM sent. Mar 23 2025, 08:47 PM
RTz Got it, and replied.
Thank you! Mar 25 2025, 11:31 AM
RTz .. Apr 5 2025, 08:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 01:24 AM |
