Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
Well I want to get these working correctly.
When I pull the heater level all the way up, hot air just "oozes" out into the cab. When I move the fresh air fan lever over, it doesn't seem to work or even turn on. The airflow doesn't increase... Also, the other two directional levers don't seem to work either- the hot air oozes out of all- defrost, center and down. Am I missing something? Is there a diagram that shows all the wiring and correct tubing for the heater and fan? Where do I start? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
Do you have a heater blower motor on the engine and have you wired it directly to see if it works.
IF the blower works the next step is to check the heater lever. The blower is activated by grounding created by pulling the lever up. Check to make sure the wire is hooked up. Get the blower working first and then start on the next problem. |
Lo-Fi Version | Time is now: 11th July 2025 - 03:31 AM |
