Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Here it is guys!
Its not pretty sitting there all naked and bare without it's Gelcoat on, BUT at this point it just has to function and be proven. It still didn't turn out too bad considering it wasn't made in a mold! http://www.aircooledtechnology.com/r_d_914_dtm.htm Nevermind those pics of engine parts- Charles goofed up when he loaded them in a jiffy for me today. (those are a newly designed piston for a wild chamber Len and I designed and a 66x100 bore size) We finished the mock up over the weekend and its ready for the dyno next week! This shroud is the first one and it is set up for guys with full external oil systems, full flow and accusumps- like my car. After I make this version work it will shed some light on what I need to modify to physically go further with to fit into the 914 and still utilize the factory oil cooler. I have two possibilities of that at the present. The other design locates a small efficient cooler normally used externally in the sheetmetal just forward of the engine toward the cockpit of the 914. This version will blow air into a duct we are making now, through the sheetmetal and out the bottom where another duct will be that has a venturi effect to help pull air through the cooler even faster as speed increases! Its amazing that I have gotten this far with it with everything else going on here!!!!!!!! For those that are not on my list but would like to be email the Mad Scientist at productdevelopment@aircooledtechnology.com |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Jake,
I need a test....can you run it at 6k for 10 minutes then miss a shift and rev it to about 9500 or 10000 and see if it survives? If it does, then it's Sean-Proof! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 9th July 2025 - 03:47 PM |
