> Raspberry 914 finally getting some updates, Exhaust, suspension and 5-lug
Stratfink
post Aug 30 2024, 06:32 PM
I bought my first (and only) 914 about 2 years ago from TDSkip after skulking around in the background here on the forum for a couple of years. I've really enjoyed the car and done a few upgrade and maintenance items (123 Dizzy, new TPS board, stereo, and some cosmetic stuff like Coco Mats). But I have been acquiring parts to backdate the exhaust, update the suspension, and to go 5-lug for quite awhile and finally got into the project. Between work and other projects it is going slow, but the deeper I get into it the more questions I have (and the scope of the project grows of course...).
Starting this thread to share some progress, but more importantly to call on the wisdom of the amazing 914 community for help since I have not done any of this work before.
Thought a good "before" pic would be a good way to start this off...
First step was getting the Monza exhaust and '75 Heat Exchangers off the car...
Generous amounts of PB Blaster were applied to the fasteners for several days before pulling this apart. Luckily no exhaust studs snapped - however in 3 locations the studs came out instead of the nuts coming loose.
You can see the condition of the threads in the picture. Also shown are the new nuts I purchased (although the copper lock nuts are the wrong thread size). I have not tried to remove the old nut from the stud now that the stud is out of the car - perhaps best to get new studs for these 3 locations. I also plan to use some anti-sieze for the re-install.
After getting the exhaust out I could see that there had been some oil leaks that should be addressed. More on that in the next post (as well as the start of the 5-lug work that I got into while stressing about the oil leaks...).
Thanks in advance - Joe
Dave_Darling
post Apr 27 2025, 05:45 AM
914 Idiot
The rotor isn't firmly held in place until the wheels are on and torqued. So it could just be that your rotor isn't quite sitting right.
--DD
Stratfink   Raspberry 914 finally getting some updates   Aug 30 2024, 06:32 PM
mepstein   Beautiful car. :beer2:   Aug 30 2024, 06:46 PM
Stratfink   Thanks Mark! The body has a few flaws but its...   Aug 30 2024, 07:05 PM
fiacra   Thanks Mark! The body has a few flaws but it...   Aug 31 2024, 09:11 AM
Stratfink   Just recently pulled the trailing arm off to do b...   Sep 2 2024, 10:48 AM
rick 918-S   Nice car. Isn't that Aubergine? I have a Raspb...   Aug 30 2024, 08:31 PM
Jett   Nice car but looks like Malaga red   Aug 30 2024, 08:42 PM
scallyk9   Malaga Red (L 30 C), a standard 1975-76 color?   Aug 30 2024, 09:13 PM
Stratfink   Malaga Red (L 30 C), a standard 1975-76 color? ...   Aug 30 2024, 09:28 PM
dr914@autoatlanta.com   looks like malaga to me!!! I boug...   Aug 31 2024, 09:46 AM
FlacaProductions   Looks like great progress, Joe. I'm usually o...   Aug 31 2024, 11:40 AM
Stratfink   To be more exact I guess it is the 3 bolt location...   Sep 2 2024, 09:03 PM
East coaster   That’s how I took mine out   Sep 3 2024, 05:07 AM
technicalninja   Those are supposed to have plastic plugs in them (...   Sep 3 2024, 01:07 PM
FlacaProductions   Here's a pic i found that shows the plugs and ...   Sep 4 2024, 08:38 AM
Stratfink   Finally getting back to the 914 today after a few ...   Jan 1 2025, 11:29 PM
Root_Werks   Looks like some great progress! Also really l...   Jan 2 2025, 10:26 AM
Stratfink   Chipping away and making some (slow) progress on t...   Mar 22 2025, 05:11 PM
Stratfink   Cleaned up the bushing - part number 914 424 224 0...   Mar 22 2025, 06:19 PM
bkrantz   Is that the bushing for the shift rod hole in the ...   Mar 22 2025, 07:38 PM
Stratfink   Is that the bushing for the shift rod hole in the...   Mar 22 2025, 09:23 PM
porschetub   [quote name='bkrantz' post='3197467' date='Mar 22...   Mar 24 2025, 04:15 PM
Stratfink   I have been thinking through the sequence of event...   Mar 29 2025, 04:54 PM
Stratfink   A couple of questions from the thermostat and shif...   Apr 18 2025, 10:21 PM
Cairo94507   Great progress. That conical screw does not look ...   Apr 19 2025, 08:18 AM
JeffBowlsby   The L bracket is for the screw that holds the air ...   Apr 19 2025, 08:25 AM
Stratfink   Awesome - thanks for the replies Jeff and Cairo...   Apr 19 2025, 08:38 PM
Dave_Darling   I have had some success wiggling the coupler to ge...   Apr 19 2025, 08:55 PM
Stratfink   Thanks for all the inputs - shift rod is done (con...   Apr 26 2025, 09:09 PM
Dave_Darling   The rotor isn't firmly held in place until the...   Apr 27 2025, 05:45 AM
Stratfink   Got the SSI heat exchangers in and the muffler on ...   May 24 2025, 07:01 PM
FlacaProductions   Really great progress, Joe! I'm frequentl...   May 25 2025, 07:55 AM
- Lo-Fi Version Time is now: 16th July 2025 - 05:18 AM
